Hey guys i need a little help, ive been looking at new rims lately and found a couple that i like all in 17*7 but im having trouble understanding the whole offset buisiness... i know that basically the offset is the distance between where the hub bolts to the centre of the rim but how does the whole +- crap work? -offset further from the hub and strut assembally??
i ask because i borrowed a set of rims of cammo last night (very much appreciated) and they are 17 with 235 on them (not sure about the offset...) and they actually have more clearance between the outside tyre wall and the strut than the 16's that i had before.... im also wondering what the recommended offset for my s13 silvia would be so that i can fit 17*7's under the car withough rubbing on the strut assembally.
any help in trying to get my head around this is much appreciated :cheers:
https://www.sau.com.au/forums/topic/217615-offset/
http://www.nissansilvia.com/forums/index.php?showtopic=75912
or
PM 'thrustt'. I think he would know the most about silvias in Alice.
thanks for the link man, had heaps of good info, shame no pics though, im still not sure what i want to go though, thinking 17*8+30 or 17*7 +38 if i can get them, not sure how they will look though, i just dont want to have them rubbing on the guards or on the strut :)
https://www.sau.com.au/forums/topic/217615-offset/#findComment-3858743
hey man, check out ns.com heaps of threads on offset. theres this 40 page post just on offset in the general chat section...
yeah i had a look, found a few but most of them are full out there 18*10 rims and shit with flared or rolled guards and i dont want that lol.... but ah well, i was thinking 17*8 +35 all round, what do you think?? yours are 17*8+30 hey?
https://www.sau.com.au/forums/topic/217615-offset/#findComment-3898837
- 17x8 +30 front
- 17x9 +35 rear
https://www.sau.com.au/forums/topic/217615-offset/#findComment-3902182
Anything higher than +15 on a s13 is retarded, especially on such a narrow rim.
lol as if rims look mean as when they fill out the whole guard, as long as they dont rub of course...
hypactv's rims fill his guards out good as :O
besides 8 inches isnt that narrow, standard 6.5 inch rims are narrow
https://www.sau.com.au/forums/topic/217615-offset/#findComment-3904468
bryyy- what are u on about man? i dont understand anything u just said.. lol
its chris here.
im not too sure about the s13 non turbo offsets but i doubt it'll be no different from the turbo models...
17x7 and 17x8 should be ok with the offsets you said... if it rubs which i doubt, just roll the guards a bit.
but remember you have stock struts
i dont think i could fit my rims without the coil overs especially on the rear
https://www.sau.com.au/forums/topic/217615-offset/#findComment-3904535
yeah i thought about that but i think 17*8 all round with +30 would be alright though, cause cammos fit under my rear no worries, like and inch clearance between the stock strut, they 17*7, so 17*8 should fit no worries cause it fills the guard out half inch each side,
recon 17*8 will fit no worries though?? with +30 offset all round?
https://www.sau.com.au/forums/topic/217615-offset/#findComment-3904596
    • So I actually had the cover off my car today, here is a (bad) pic of the setup. I have an oil cooler thermostat block, the temp sender is straight in there. The pressure sender has a short AN line to a T piece which is mounted (hopefully cable tied counts as mounted....) on the chassis. BTW every fitting you could ever imagine exists....just depends what they cost and how many you need. Raceworx AN adapters are here: https://raceworks.com.au/fittings/adapters/, I think you said you need BSPT to AN (https://raceworks.com.au/fittings/adapters/bsp/tapered/an-to-bspt-adapters/) and AN to NPT (https://raceworks.com.au/fittings/adapters/npt/) BTW, braided line is super simple to make. It looks intimidating, is not.
    • Perfect day for a pie, really needs a soft top in this weather though
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
