Hi Guys,
Does anyone know of any reliable importers who can ship to Melbourne? I've looked at using J-Spec but they don't seem to reply to emails nor do they have a contact number, so I don't think I'll be using them. If someone could recommend me a decent importer it would be greatly appreciated.
Thanks,
TCX
Edited by tcx
https://www.sau.com.au/forums/topic/217717-import-dealers-melbourne/
Hi Guys,
Thanks,
TCX
J-Spec gets hundreds of emails a day, so you just need to be a little patient for their reply :P
other than that, they are a good import company, i got my r33 through them, very happy, i'd recommend them :)
Carizma International
Kamikaze Motors
Or ring Tim (Soon to be posting some cars for sale on SAU), the number posted in my signature.
He is a private importer and has some nice cars for sale, well looked after and good condition.
Call him for more details.
+1 for being patient with J-spec. They helped me import my V35 and were very, very helpful once they get going.
As an alternative, check out the guys at SSV... another great bunch of guys who know their stuff.
or give us a call at 03 9415 7150 or email/PM if you can't wait til then!
cheers,
david @ Carizma
tell us you're from SAU and we should remember you.
I'm looking at Carizma, will probably go to their office on the weekend.
I had the same reservations about J-spec when I was looking to choose an importer. I stuck with them and can honestly say that they've been fantastic from the get go (3 weeks into the process now). Craig is very patient and answers all of my questions, even when I was asking nearly daily whether the car had been shipped yet!
Check out this place in Bayswater, i picked up my S2 Stag from here just over a year ago.
Very friendly and helpfull.
They usually got a nice selection of cars to check out already landed ready to buy.
Been around for a while.
www.luxuryandperformancevehicles.com.au
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
