Nulon oil
24 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hi everyone.
I recently fell for the propaganda from Nulon. I bought Nulon 10w-40, since then been having problems. Engine revving strangely. Feels like it's not as free revving at high revs etc. I used Shell 5w-40 before and had no problems.
Has anyone tried Nulon, or had problems with it? Feedback would be appreciated. I'm trying to eliminate things to get to the bottom of the problem.
Thanks.
https://www.sau.com.au/forums/topic/217719-nulon-oil/
best to stick to the good brands ive found :nyaanyaa: but yet again your problems may not exactly be oil associated, VAC leaks, spark fuel can also cause these dramas, but as stated above if your unsure drain it replace filter and oil with quality brand and see if it helps
Good luck
https://www.sau.com.au/forums/topic/217719-nulon-oil/#findComment-3842293
probably pointless to the question your asking about nulon but i used castrol in my car once. each time i started it cold could hear tappets clicking (meaning all oil is drained out of head and not leaving a film on anything). changed it again 2 weeks later to an $80 for 4 litres motul and havent looked back since. i figure oil is like blood in your body so for the extra $50 or so when your doing a service its well and truely worth it. On the other hand some people say oil is oil but thats just my 2 cents worth!
brett
https://www.sau.com.au/forums/topic/217719-nulon-oil/#findComment-3842626
i know audi use castrol or motul if you have the R or S series , ive got shell in the Audi and motul in the skyline havent had any problem with them
every car has different clearences .. mightbe worth it changing oil n filters
P.s use oil flush t o completely get rid of old oil from the motor helps it keep it sludge free
https://www.sau.com.au/forums/topic/217719-nulon-oil/#findComment-3842876
brett
Yes, i have the same with the Nulon. Tappets clicking on start up. Highly irritating, just another bad experience i guess. Maybe i should stop being so cheap and buy good oil. I have used Nulon additives a few times and had no problems.
https://www.sau.com.au/forums/topic/217719-nulon-oil/#findComment-3843309
i have alot of different oils in the 4 years ive had my 33 ( shell motul nulon royal purple redline VP racing oils and more) full synthetics are the way to go. you will also find that the older the engine the heavier wheight oil you need to use eg older 15w50 newer 5w30 or 10w40 winter you can use a slightly thinner oil it holds its consistancy in colder climate in summer the oil thins out as it gets hotter it will not protect the engine as much if you are using 5w30 or 10w40 in older engine.
the best thing to do is use an oil flush and put in a better oil.
i found that the best oils for me where royal purple, redline, VP racing and motul is borderline for me.
my 2 cents worth
cheers marcus
https://www.sau.com.au/forums/topic/217719-nulon-oil/#findComment-3847530
+1 for motul turobolight I used it in my NA/34 it felt much better then when the service center was putting in mobil. Its not even that expensive I think i payed like $65-$75 for like 5 liters at autobarn in browns plains. I used both 5w-40 and 10w-40 both seem to be fine id recommend motul. Never gave me a single problem and I used it for about a year and a half.
https://www.sau.com.au/forums/topic/217719-nulon-oil/#findComment-3848464
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
