This is my first attempt at adjusting the Base Timing on my R33Gtst. I got the timing light connected up and checked the timing. I can see the notches on the crank and the Marker on the caseing that you line it up with. THe maker seems to be pointing to the second notch from the left. So my understanding that this means the timing is currently at 5degrees BTDC.
The problem i have is that the CAS is pushed hard up to one side so i cannot advance the timing anymore. How do i advance the timing anymore if i cannt turn the CAS further,my understanding Base timing should be 15BTDC.
Does this mean the my CAS is on its way out and need replacing? Or does my Timing belt need to be replaced and everything need to be lined up?
https://www.sau.com.au/forums/topic/217828-base-timing-and-cas/
As the engine rotates, the first mark on the pulley to align with the marker on the timing case is 30BTDC, the last mark is TDC. The marks are 5 apart. So, yes, you seem to have 5BTDC.
What happens when you move the CAS the opposite direction?
pushed up all the way in which direction? the cas turned all the way clockwise is full retard and all the way anti-clockwise is full advance. check this first, if its all the way anti-clockise or full advance then its possible the cas may be one or two teeth out.
If i move the CAS in the oppisite direction (Clockwise) the idle goes all over the place and cannot even read with the timing gun because it looks as if the timing is fluctuating from about 0- to somewhere before the marks even begin.
The CAS at the moment is rotated fully anti-clockwise so the bolts are hard up againts the right hand side of the CAS.
So when i look down at the Crank it lookes like
Marker ---> |
Crank --> | | | | | | |
0TDC 5BTDC 10BTDC 15BTDC 20BTDC 25BTDC 30BTDC
So i presume it reads as above?
it is possible to put the cas on incorrectly and it be out one or two teeth. what timing light are you using? where are you getting the signal from? have you tried a different timing light?
if your confident your timing light is reading correctly you could try, unbolting the cas, pull it off, dont turn cas the shaft yet, have a look to see if the half moon shaped locating pin on the end of the cam shaft, is missing or not, if it is there the cas will only go on one way.
if its not the cas may have been put back on incorrectly so its out. then with the cas held so the shaft is facing you, turn the cas shaft anti-clockwise a little bit so when it goes back on it is one tooth advanced.
then put the timing light back on it again. you may have to move it more teeth to get it right.
This is the first time using this timing gun. Brand new, its only a cheapy $60 job. Im getting the signal from the first plug. Its an inductive type. So ive put the clip around the set of wires going to the coil pack.
Ive had the CAS off before, and looked at the teeth and half moon pin, they all look to be in good order. So i gather when i put it on last time there was only one way i could have put it on
Only if the half-moon key is missing froom the end of the exhaust cam. If the key is missing, and you fit the CAS even 1 tooth out, the engine will not start (been there, done that).
The safest way to get the correct reading is to insert a plug lead between the coil and the plug, then connect the inductive pickup onto the plug leag.
So say if the CAS half moon key is there cus im 99.9% sure it is, last time i looked. What could the problem be??? Maybe the Timing belt being a tooth out? The cars getting close to the 100,000k mark. Im pretty sure that sticker one the cam cover says to change it every 100,000ks.
i would get a better reading than just clamping the wiring loom. like blind_elk has said insert a plug lead between the coil and the plug. also make sure you are unplugging the aac valve before take a timing reading, so the engine sits at base idle.
hey mate... awhile ago got nw water pump installed and ever since then had the same symptoms.. weird idle if you moved the timing anywhere away from full advance...
recentlly got new timing belt and all that..
turns out the guys that done my water pump put my timing belt on my exhaust cam one tooth off...
all fixed now.. runs like a dream
id say your exhaust cam is out by a tooth..
Almost certain it will be a half moon key as per the majority of Skylines and also Zeds using the Bitsashitty CAS. I'm told cheap timing guns can give double readings, mine definately does on my GTR as if I set it to the correct value visually it runs like crap and the CAS is adjusted right to one side. If I set it to double the value I want then the car runs beautifully and isn't pinging. I have no idea where the double readings come from but it's in several threads on this site.
Cheers,
Matt
Hrm, not sure about it being a tooth out. I took off the timing belt cover. Looked at the notches and everything seemed to line up. I decided to move the exhaust cam advanced 1 tooth. Then put it all back together. I got the timing to 15degrees. The exhaust note seems a little different now. Car seems to perform a bit better.
Is there anyprob with moving the cam 1 tooth advanced from where the notches are?
sounds to me you need to go through the whole exercise of 'fitting a timimg belt' to make sure everything is correct. cound be on the crank that things are wrong and you wont see that unless you pull it all out...(being the timing covers, main pulley, etc etc etc)
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
    • Oh, and as for everyone with their fuel economy changes, I switch between E10 and 98 in the company car. Even do when I had personal cars that could run on E10. You know what changed my fuel economy in any noticeable way? How I drove, and where I drove. Otherwise, say on full tanks of just back and forth from work only (So same trips, same sort of traffic), couldn't notice a difference that I can correlate to the type of fuel in use. In the current vehicle, that's over 42L of USABLE fuel. While 98 is all "more energy dense", it also has higher knock resistance as it takes more energy to get it to ignite too. The longer hydrocarbons, typically more tightly bound. So running the same ignition map, can also produce less power, if there isn't enough time to get it all burnt through properly, as yep, the flame propagation speed is different from lower octane fuel to higher (Higher has a lower flame propagation, due to the more tightly bound and harder to self ignite funs. This is also typically where, a vehicle that is designed purely to run on 91 (Whether it be E10 or normal 91) usually sees absolutely no real world difference in fuel economy for the normal man, woman, or dog.
    • We've got some servos around me that have 91 with E10, 91 (no E10), 95, and 98. At those stations the change from 91 E10 to 91, is typically around 8c/L.   But lets not get started on the price of fuel in Oz. It's ridiculous. All the service stations around me, bar one, the price of fuel has been over the $2 mark per litre for the cheapest, 98 being around $2.45. That one service station is a CostCo, fuel from it comes from the same refineries, and makes no pitstops, it runs great, including the 98. In fact, I've had no issues on CostCo fuel, but plenty of issues at other stations!. The CostCo fuel, was $1.65 roughly this week for 94 with E10. $1.88 for 98. Servos directly across from it, $2.10 for 91 E10, and $2.48 for 98. The part I had to laugh at? If I drive multiple HOURS away from Brisbane, say out near Nanango, or Kingaroy, or even out to Goondiwindi, the price of their fuel, is the same as what it is at the CostCo... Oh, and that BP servo at Goondiwindi is HUGE and goes through epic turnover of fuel, so it's not sitting there for weeks going to shit. And what blows me away, my mate is one of the people who drives the Fuel Tanker all around QLD, delivering to all those places. At the same company his previous role was doing the "local haul" deliveries... Same truck, same driver, same pickup point it all comes from. So you tell me, how the hell it is 60c/L CHEAPER for fuel, when nearly all else is equal, except they require a B-Double to drive half a day out of Brisbane, and half a day back, every second day, compared to the delivery that can be under 30 minutes drive from the fuel pickup point... Not to mention, go five blocks down the road, and Ampol to Ampol will vary 30c/L... And I've had this conversation with my mate... The way it's priced, is just typical, pure and utter rubbish... He also does runs from Brisbane, to all over QLD, down to Newcastle, Sydney, Nowra, Melbourne, Geelong, and even out to parts of the NT depending on the companies needs. His main stuff is all the longer distance away from home for a few days at a time, then when he's back, he loves to just pickup extra shifts wherever he can in whichever truck, hence all the weird different places.   Oh, as for getting E10 into all the fuels in Australia... It was very quickly highlighted, that we don't have enough biomass available to use to make E10 sustainably like they require, and it would dramatically cut into our, and the worlds food chain supply...   I vote we all just start running on liquid methane gas... Plenty of that just getting tapped off at tips from underground decay... (Note, this is pure just stupid commenting. I could very easily highlight the reasons its not a good idea especially on scale...)
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
