i would have one myself but unfortunately the upkeep is more expensive than the R33 .... they are absolute pricks to work on and a lot of mechanics either dont wanna know or charge you an arm n a leg to get them fixed.
Very cramped inside. Sexy cars tho :P
https://www.sau.com.au/forums/topic/21804-z32-twin-turbo/#findComment-463162
mate of mine has had 2 and they were fairly quick... he never modified past the filter/exhaust/boost stage so wasnt too expensive.
only problem he ever had was the sump plug falling out one night!
i believe the cooling issues come up when you really modify the engine but its nothing a good radiator cant fix.
having said that they are hard engines to work on, with anything more than a simple service requiring a specialist garage. very nice cars though as long as the 2-seater thing doesnt bother you
https://www.sau.com.au/forums/topic/21804-z32-twin-turbo/#findComment-465009
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
