You cant get a pod or an exhaust over 90db engineered.
You could only get a pod engineered if it does not make excessive induction noise.And you would have to take it to the RTA to get a noise test done,which cost a few hundred per test.
Why would you spent around $1000 each time you wanted to update the certificate?
Get all your mods done then get it engineered.
the more i hear these things the more i think the arc super induction box iis worth the price...no hassels at all :( as for the exhaust, i have a full 3" system, if somehow i stuck enough resonators to get it under 90db would i still need a rta db test or just get that done when the engineer writes the certificate for it.
If its under 90db it will pass.
you cant engy the pod as other's have said.
you technicaly cant engineer to exhaust unless you have an emission's test done with it
your idea about the arc box is wroung, it's an intake modification, therefore it needs to be emission's tested...
if you wished you could pay the engineer's asking price for cert, then ad stuff aloung the way, depending on the engineer you can pay per mod once the initial engy cert is done.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
