Just a quick question recently had engine built by sydney workshop. Had it a week & it blows white smoke only sometimes. Would it be because its just a fresh engine or would it be other circumstances to the problem. Has me slightly worried any ideas guys why this is. Cheers
https://www.sau.com.au/forums/topic/218097-new-engine/
one of your valve stem seals could be causing you a bit of trouble....maybe not sealing correctly because it was damaged when they incorrectly assembled the head last time....or damaged when repairs were being made to the valve train.
send it back and demand they fix it!
https://www.sau.com.au/forums/topic/218097-new-engine/#findComment-3848302
Your not having much luck with this engine mate :P
If it were me, I would be taking it to another workshop and sending the original engine builder the bill for any repairs that are needed.
https://www.sau.com.au/forums/topic/218097-new-engine/#findComment-3848322
Yeah no good blitz. Noluck me should have maybe gone somewhere else.
https://www.sau.com.au/forums/topic/218097-new-engine/#findComment-3848358
your description of the problem is very general and not specific enough to necessarily indicate a problem. as you dont indicate when the smoke is seen (idle, under load etc?), it could be possible that the smoke your seeing is just a bit of richness added by your tuner for safety?
https://www.sau.com.au/forums/topic/218097-new-engine/#findComment-3848498
ive seen the fuel and ignition map in this car....its definately not fuel related.
its white oil smoke 100%
https://www.sau.com.au/forums/topic/218097-new-engine/#findComment-3848570
Was the engine correctly run in?
Idle it for any extended periods of time (more than 30 seconds) and you can bet your arse you will glaze those bores.
If it has been run in correctly, then you shouldn't have to worry about this.
Any chance you could be more specific on when the smoke is seen?
https://www.sau.com.au/forums/topic/218097-new-engine/#findComment-3850314
Also, do not do as suggested and take it somewhere else and send in the bill to the previous workshop. You will not get one red cent out of them. The law states that a workshop MUST be given the opportunity to rectify the problem at their cost (if it's their fault), otherwise you will have no legal claim to monetary compensation.
https://www.sau.com.au/forums/topic/218097-new-engine/#findComment-3850319
Mahle Pistons
Eagle Rods
Tomei cams 280
R33 crank grubbed
N1 block
Greddy oil pump
Tomei springs & buckets
Hks to4z
Hypertune Plenum
Sard 700cc inj
so it was just a freshen up then... lol
what about the head specifically, did they replace things like valve stem seals?
has it had a compression test and leak down test since the rebuild?
thats a piss off, after spending that much coin and still having problems.
https://www.sau.com.au/forums/topic/218097-new-engine/#findComment-3851112
Your correct, however as I understand it the workshop in question has already had to rebuilt it for a second time due to valve train issues after the initial build.
https://www.sau.com.au/forums/topic/218097-new-engine/#findComment-3851116
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
