hey guys
this question is aimed at those who have done a bit of rb25det tuning;
for a stock turbo setup, does MBT (Minimum [spark advance for] Best Timing / Maximum Best Torque) occur before knock?
or will an rb25det stock turbo knock before it reaches MBT?
cheers
https://www.sau.com.au/forums/topic/218145-tuning-the-rb25det/
getting MBT (maximum brake torque) is achieved by igniting the fuel mix wen the cylinder reaches peak cyclinder pressure (top dead centre). as the air/fuel mix takes time to burn the spark must b initiated prior to the crank reaching (tdc). the tuner must no exaclty wen to start the burn to achieve (mbt). there are many variables that affect wen the spark must occur such as air/fuel ratio, charge temperature, load, boost ect. generally mbt is found by advancing the timing (with the correct a/f ratio for the condition already set) untill the knock threshhold is found and then backing off a few degree's to allow for any unforseen conditions that may see the engine knock. generally the more spark advance present the more efficient an engine will b.
i'm not after someone to tell me how much timing my engine will take.
some people have very definate opinions on MBT and knock, EG, some say that on an NA engine you will 100% hit MBT 2-5degrees before knock. others say that on any turbo engine you will never reach MBT before knock. others says that on engines such as CA18DET's you have something like 10degrees of headroom after MBT before the onset of knock
i thought there may be a general rule regarding rb25det's
I think i see what your getting at.
I hear many a pro and home tuner say RB's are especially sensitive to knock. I take this to mean the IGN numbers needed for peak tourqe are quiet lose to det levels. Often why a car comes back from an inexperienced tuner who used the dyno only, and didn't compensate for real street load = det on the next 40 degree day with 2 passengers.
sall i got ha :thumbsup:
Took me 2 good years before I considered myself a capable tuner, and I know\knew quite a bit of stuff already, and my background is IT orientated. High level too.
You can't just go out and buy some tuning gear and tune a car..
Agreed. I been at it for nearly 5 years now... and I still have many questions that i ask my friends who tune cars all day.
Id rather dyno a car then road tune these days though.. starting to get lazy
this is true, but you have to start somewhere don't you I'll just be very conservative with my boost, ignition and afr's till i feel more confident at tuning then I will get it checked over by a professional
well that would be a big problem wouldn't it, but that could happen to anyone really, I guess ill know there is something wrong if it starts knocking like crazy, but im sure there are other side affects that your talking about egt's emissions?. Why all the negativity about someone trying to learn how to tune themselves, considering you did it or did you just upload a program into your head like the matrix?
lol, well, you're opening statement was pretty poor.
Sounded like you just wanted to do a few maths sums, and just put everything in, and off you go, tune done.
Also, there are so many factors involved to your question..
I guess i was lucky when learning how to tune. My mate owns a workshop and i can use the dyno when i need it. I was allowed to hang around and help out with tunes he was doing... and even drive the cars for him while he was road tuning.
I have a few mates who have been tuning cars for years before i started as back in the day (late 90's) there was not many tuners around that could tune our turbo datto's (microtech lol) so we learnt for ourself
I put in many many many hours have been invested into this. Its not something that you can work out in 6 months.
Good luck with it anyway.. if there is anything i can help with let me know..
Id swap places with them. any day of the week.... what does knowing how to tune get you ??? it dont get you laid... believe me.
I wish I was as lucky as you Guilt toy and have mates who tune cars for a living and own workshops.
I would give anything to be a capable tuner and engine builder.
My mates are too concerned about getting paid and getting laid.
ah cool im sure I will have plenty of q's when I get started. I know I'm throwing myself in the deep end but this is something I want to learn how to do, just for the satisfaction of saying i did it myself. So fingers crossed I dont blow my engine up :P
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
