well i got her back, they managed to pull out 215 rwkw, thats as far as it can go without injectors and pump, and now on hi boost the engine cuts out for a second, then goes again, and the knock sensor goes up to as high as 94!!! bbbbaaaaaddddd! so low boost it is till it goes back in on tues for pump and injectors...money money money
94 knock level f@#k thats not good, was ya engine warning light cuming on???
were u resetting it after every boost up?? coz i think the numbers just keep adding up if u dont reset i think u press up to highlight it then press right 2 reset it then press down 2 un highlight it
  • Replies 59
i did say 204rwkw 10psi with everything stock... simon is making over 280rwkw with stock inj... just upgrade the pump, and your cutting out thing may be as i explained before the spark gap, as fuel cut should have come off with the power fc install? or even a coil pack breaking down?
good going with the 215 what boost was that? and when u made the 206 was that with the fc in untuned or stock ecu, i would have thought they could have made more then 10kw with a tune..
i took it back to simon at morpowa to show him what its doing, but the bitch didnt do it!!!! and boy did he give it a hard time!
205 kw was before the fc on 11 psi...215 was at 13 pound,with pfc, they said it was as safe boost level as they could get it with the standard pump.
and they also told me the injectors are at only 80%, so they have a little more puff to go before they need replacing.
im only after a few more kw, around 230-240 and ill be happy.
so it goes in monday for bosch 044 i think he said.
spark gap was set before the tune yesterday, and splitfire coil packs will be in a couple weeks time,
yeah the engine light was coming on, just that once when knock went over 60.
and i reset it after every hard boost, yes
  • 4 weeks later...
just to quickly add to what was said b4... there is absoloutly NO limit (that we have found yet) to what we can re map the standard ecu to and with, AFM's, injector sizes and turbo's!!! as shys6 said b4 we made 360 sumthing rwkw's out of our rb20!!!!
n i would suggest a walbro 500hp pump in ur tank man, they are pretty much a straight fit, no mucking around! sumtimes it gets a bit tight putting a big bosh down in the tank of the r33's n s14's coz it has to squeeze down next to the fuel level sender and all.. but obviously the bosh will still work!!!
hope yu get it all done soon man, will be good :happy:
dude go for the walbro > bosch.
im looking into it myself....apparently the bosch in-tank fuel pump doesnt come with 'everything.' or you could bust 400 or so bucks for a nismo fuel pump haha
walbro would come with everything the bosch one would. With the bosch u need to modify the holding bracket and use a hose clamp to put it in place.
I would go bosch over walbro, but thats personal choice.
i am looking at getting a bosch 040....ryan is helping me put that in....Walbro $170 and Bosch 040 $220....i would rather go with the Bosch 040....just a lot better
Arent Bosch just better for much higher kw applications? and Walbro are fine for about 250rwkw?
Bosch 040 i can get one for $220.....and its not hard to install it or so i have been told....so why get a nismo one....for around $400.....and why get a walbro pump for $170 when for $50 more u can have a much better and reliable pump in ur pride and joy...
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
