Well guys,
My question i think will be relatively simple for most peps in this forum 8D
my brother in law has upgraded his R33 GTR and said i can have his Stock Turbo and Injectors. But can a GTR R33 turbo bolt onto a GTT R34? Or do i need adaptors? If so is it worth it? The wheel is still ceramic yeah? i assume it should still be a better turbo for the time being until i get a better turbo..
In the case it does bolt on i'm assuming i will need upgraded injectors.. but still his injectors are better anyways.. but correct me if im wrong but isnt there an issue of side feed v top feed when it come to GTR and GTT?
Feedback, advice on what you think is worth doin would be great.. also have a power fc which i wanted to get in asap.. but am i worth getting Turbo installed (if there no hassles involved) before i install pfc and tune?
cheers
https://www.sau.com.au/forums/topic/218173-r33-stock-turbo-in-r34-gtt/
A GTR has two turbos, a GT-T has one... you realise this dont you?
They are also a different flange/bolt pattern also
So to get two GTR turbos working (as one isnt an upgrade, its smaller than a GT-t turbo, as there are two of them).
Two manifolds
New custom oil/water lines
New/Custom intake piping
Adpators for the manifolds
New exhaust to cat (at minimum)
Management
Adaptor loom/rail for the GTR injectors as they are not change over
And so on...
IMO totally pointless.
yeah i thought they would be a different flange when he said i can have it.. yeah i know there is two turbos.. lol.. i shouldnt even have a skyline if i didnt know that.. although i didnt know they were smaller turbos.. and yeah i thought i could jus use one... however smaller turbo.. too much work for a temp thing it seems..
always worth the ask.. gained my new knowledge for the day now.. thanks anyways.. you have pretty much confirmed my feeling it wouldnt be a simple process
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
