Hey Guys, i didnt wana put this in the forsale section, coz i just wanted to give the Melbourne people a heads up first.
Were wrecking two R33's very soon, heaps of after market parts such as
- Turbo back exhaust
- custom interior
- custom boot install
- r33 gtr rims
..and much more! No prices as of yet, so plz dnt ask me "..do u have..?" or "how much for..?"
Ill let yaa all kno when were pulling them apart (possibly in a few days)
Btw one of the cars belonged to an SAU member, its a black r33 series 1..anyones off here??
-Ferah
https://www.sau.com.au/forums/topic/218188-wrecking-2-r33s-soon/
Ferah - come on, your aware of the rules we've been over it a few times.
We've got sponsors and the 100's of other people that follow the rules, you need to also.
And yeah i know i look like the prick cause i'm closing it rah rah rah, but then people shouldn't be creating it so i dont have too
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
