FOR SALE:
A set of 6 upgraded injectors, will fit GTR. Im selling my GTR therefore I don't need them anymore. Flow is 550cc. In very good condition.
Asking price: 350$ ono.
Turbosmart Blow Off Valve. Supersonic type 3. Very loud, in very good condition.
Asking price: 250$ ono.
Standard Subaru WRX wing from 97 model (low style wing). In very good condition, with braking light. Silver colour.
Asking price: 100$ ono.
R33 Skyline GTR Vspec. 25k worth of mods, won't embarass you on the street. 288 kw on 1.3 bar boost. Has AVO intercooler, tein suspensions, semi slick bridgestone with TE37 17" wheels, 4wd/2wd converter, 4ws/normal converter, single plate exeddy clutch, AVCR, oil and water temp, oil and boost pressure, and voltmeter gauges, Greddy gearknob and oil cap, oil cooler, hks pistons, apexi rev meter, etc etc.
Asking price: 52.000$ negotiable.
Canon BJC5100 for sale, print up to A3 size.
Asking price 150$ ono.
Call to 0415210220 or email to [email protected].
  • 1 month later...
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
