Now that I have new wheels I'm selling my as new old wheels. They are 17x7 +45 offset and WILL clear Nissan 4 piston brake set up. They have AS NEW made in Japan 225/50/17 Bridgestone G Grid II tyres on them. These are not chep chinese rubbish. I bought the wheels and tyres brand new. There are no marks at all on the wheels and there is no camber wear on really any wear at all on the tyres. Asking $600. Here is a pic of them on my car.
Located in Launceston but will freight no problem.
Any questions please ask.
Cheers
Rich
0407332944
https://www.sau.com.au/forums/topic/218544-wheels-for-sale-17-inch-5x1143/
Sounds good Luke, I hope you are still enjoying the 180!
What is your opinion on these (for the car)?
Damo (Djrift) has first dibs on the rears at this stage, but would obviously be looking at $300 for them with tyres if everything goes through.
haha yep its still going... wheel alignment done today but they cant get it quiet right because of the spacers in the crossmember but oh well... 12psi now :P goes abit better :D
yeh they would look alright... wouldnt have any scrubbing issues in the front but my best guess would be they would sit in a fair way at the rear being a 7 but it depends what kind of look you are trying to achieve :) maybe some more bolt on 25'z? hehe
yer consider the fronts sold for 300 when u decide to part :)
Edit: just noticed gregs reply on NS about his 18" koya's... they looked really good on tha 33 :) fronts sat perfectly and the rears sit around the same as the enkeis...
Edited by toffaz
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
