Hey,
Just continuing my existing discussion about will the group buy brake lines fit my R33 GTR I've taken a few pictures of what my brake lines and rotors actually look like.
I'm getting the feeling they might not be standard size, can anyone help me by confirming?
I did some measurements but wasn't sure what to measure, anyway what I have is:
Front
Overall rotor size: 33cm
The disc part of the rotor (the silver part) 5.5cm
The centre section of the rotor - approx 19cm
Caliper length: 25cm
Rear
Overall rotor size: 31cm
The disc part of the rotor (the silver part): 4.5cm
Centre of rotor: 18cm approx
Caliper length: 17cm
All the measurements are approximate of course.
I have a lot of pictures because I'm in a rush, just a little worried that the brake lines I bought don't fit, and I'm unsure if the pads I bought are correct.
After the pic of the second disk they are all the pics of the rear rotor and lines...
Regards,
Gareth
best to measure the whole disc diameter. standard is 324mm with 30mm depth.
most likely they are standard size discs. also if they are larger than standard the calipers will have some sort of adapter between the hub and the caliper to space it out
But I did measure the disk, it was roughly 33cm, so 324mm sounds about right.
And the rear rotors, I assume there standard size as well?
Disks are Project mu, lines look standard, front are the scr pro 2 piece and rear just sloted
Thanks a lot for the info, if the lines are standard than the braided lines should fit, I just can't see how :blush:
I'll look at getting someone else to install it if I can't work it out.
Thanks a lot for the info, if the lines are standard than the braided lines should fit, I just can't see how :)
I can't see what your problem is. The braided kit only replaces the 2 rubber hoses, the standard steel hoses remain.
On the front, the block bolts to the upright.
One braided hose (from memory the longer one) goes from the block to the inner guard where it joins the steel tube at the right angle bracket on the inner guard.
The other braided hose (from memory the shorter one) goes from the block to the joint for the steel tube that goes to the calliper.
On the rear, the block end of the braided hose bolts to the steel hose that goes to the calliper.
The other end of the braided hose joins the steel tube at the right angle bracket on the inner guard .
Cheers
Gary
Cheers
Gary
Sorry about the multiple threads, I was trying to make it easier for anyone who was searching for info on the same problem in the future...
Ok, the problem is what 2 rubber hoses?
I only have one from memory, although the pics make it look like there are two rubber hoses, so I will confirm again tomorrow night.
Anyway, here's some edited pics I have uploaded.
BrakeWest has advised that the rear looks lines look different to normal, do most GTR's run a flexible hose directly to the caliper?
The guy at BrakeWest has offered a full refund or if I can take my lines off he will try and make some that match, is it still a good idea to get braided lines?
Oh, rear rotors are stock size so I should be fine for pads :P.
Found out the black lines which I was calling "rubber" are actually Japanese braided lines, they're just really dirty.
I'm getting some custom lines made up to fit in here that are ADR compliant and getting a refund from BrakeWest.
BrakeWest's customer service skills are excellent and I'd certainly buy off him again, its just that someone else has offered to do some custom lines at an extremely cheap price :P
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
