  • Replies 71
I have a R31 skyline with a RB30E NA, and that thing pisses on SR20DE manuals.. And i dont have much mods on it, just exhaust, pod, timing etc.. I know its a skyline forum, but i would go with the silvia if the car was going to be NA. Better power/weight, a bit sluggish as well, but not as sluggish as a 1500kg NA 2.5L :D
im not at all biased, my mait easily has one of the nicest looking silvia's ive every seen, it will out corner my car neday. but just doesnt have the feel of my car on the road. It is also the NA CA18DE and well lets just say its a joke.
ok cross my heart...
Cold morning...
@ 3 lane hwy...
@ light; goes Green
we took off
Silvia was faster at the take off about a 1/3 length...
then as soon as I hit 3k rpm and over in 2nd and I was pulling infront of him, just saw him pass my right hand view mirro...
there was two people in the car in skyline, there was only driver in silvia....
we both backed off at 4th gear 4000rpm... :(
*this was happen @ private road*
cheers
Joe
ya know u ask this question in a silvia forum u'll get a different answer. alot of what is said here is biased and thats no shit. being a fan of both silvias/skylines i think the sr20de is rather good and would go alright. as for people saying they piss over ca18det's in rb25de's well then i think someones pulling their chains. cause a good driver of a turbo ca is not slow thats for sure
mm definately go na rb over na sr (105kW & 178Nm or 117kW for s14 sr20) or ca (100kW & 159Nm) (cough laugh)
power isnt the only figure to quote here guys, you gotta think torque aswell - the rb 25 shits all over either of the 4 cylinders just cos its got the extra 2 cylinders - 142kw and 231Nm of torque means it is not a slow car -sure not as fast as the turbo- u'll get a manual under 7 sec with mods - and whoever is quoting 1500kg for a 33 i think is a bit off - i'm sure mine doesnt weigh anything like that - otherwise i wouldnt be able to whoop vs commodores with a totally stock car (not nemore tho) which weigh in at 1430kg would i?
u also gotta consider longevity - the rb 6 is gonna rev for longer than a ca 4 and probably as long as an sr (before i get pm's telling me the sr is 'bulletproof') not too mention value holding - as soon as the 15yr '89 model silvias come over next year cya lata silvia values
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
