Hey guys, little while ago there was a post where someone sourced some oil filter with the nut welded on top of the filter. Tried searching for it but couldn't find the post. Anyone know anything about them or been using it? Just curious cus i've runned out of oem oil filters and wanna to give them a go. Thinking would make it easier as i don't have a relocation kit.
https://www.sau.com.au/forums/topic/218678-oil-filter-with-nut-on-top/
autobarn sell a 'drift' branded oil filter with nut on it.. its blue! cost 20 odd busk though ouch :)
You're on to it mate, that's the one URAS is recommending,hey what's $20 bucks for the features this filter has especially the ease of getting it off.
I would still recommend screwing these filters on by hand as normal if you can,and only using the nut for removal as if you use a spanner to do them up they will get powerful tight,you know when you put on a fresh filter and tighten it up that you can back it off easily if you want to straight away, but try it in a week and you know how hard they get,just my 2c worth Cheers Grey Pearl.
If a filter is done up to the right torque settings, you shouldn't need tools to remove it.
Every single car I have purchased in the last 5 yrs has had some spanner in the workshop try to tighten the neck of the friggin filter, resulting in squashing and possible damage to the rubber seal, and making it damn near impossible to get the filter off after the heat has helped it to stick.
All cars (including my GTR) had a screwdriver help me to convince the filter to let go and give up, but after that, hand tight has been more than enough to make a strong seal with the filter and make it possible to get off by hand only.
B.
My hand and filter removal tool doesnt fit down there in a bnr32 :P
yeah exactly my problem
I believe this is the topic you are refering to
http://www.skylinesaustralia.com/forums/Sw...bl-t204892.html
That's the one, thanks for that cooper. Looks like it hasn't been updated. Has anyone been using these?
You do them up about hand tight, but dont use anything else to do them up. I have heard stories of engines who have been destroyed because the oil filter was over tightened, something broke off and blocked off the flow. Do it as tight as you can by hand, but you will need a tool to get it off. If it is loose, it will leak oil
LoL at some of the suggestions.
Filter removal tools are just that.. for removal; u never use a tool to tighten a filter.
Remove filter, clean o-ring seat, lubricate new filters o-ring, tight by hand with moderate amount of force - done.
there are some orange filters out there that have the end you grip designed with a grip like paint on them to help you remove them ;)
Your talking about the Fram Grip, I think.
In that famous oil filtration test done years ago, Fram didn't come up that well considering the cost.
Edited by GeeTR
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
