Well... if you want to get technical, it runs a two stage boost. First 5 psi and then up to 7psi at higher revs. You can earth the one wire and make it 7 psi all the time though. This is the same for the R33. R32's run 10 psi.
Just to clarify, I'm talking about GTT's, GTSt's here... not GTR's
https://www.sau.com.au/forums/topic/218768-r34-question/#findComment-3860135
Found it, R34 GTT Stock boost is 7psi, just under 0.5 bar.
R34 GTR is same as 32/33 GTR... which is what Topaz was referring to I believe.
Wow, I really thought the GTT's were 11psi like the 32GTR's. 7psi is shit! :P
Not sure what 33GTR's are stock, 34GTR's are 1bar stock.............................. I'm 95% sure
Edited by Topaz
https://www.sau.com.au/forums/topic/218768-r34-question/#findComment-3861541
That changes when you get the RB20 actuator yeah??
10 psi??? :P
You're doing that to your car aye??
https://www.sau.com.au/forums/topic/218768-r34-question/#findComment-3861829
i am running 0.85 bar(12 psi) daily.... izit bad then?? lol
12 psi will be fine, but you may want to check that its not leaning out at all. Upgrading your fuel pump is always a good idea when running more boost. Probably wouldn't go too much higher than that until you have some other bits and pieces to support it.
10 psi??? :)
Yep thats right :D Cause the R32's are 2 litres, they run 10 psi to make up for the smaller capacity. By changing to the RB20 wastegate actuator, you are getting 10 psi instead of 7 psi. This is a lot better than a boost controller as there is no chance of boost spikes, therefore safer for your turbo. You still need to ground that one wire to get rid of the two stage boost, and then bypass the solenoid. There is a tutorial somewhere here on SAU :)
https://www.sau.com.au/forums/topic/218768-r34-question/#findComment-3862342
Yep thats right :P Cause the R32's are 2 litres, they run 10 psi to make up for the smaller capacity. By changing to the RB20 wastegate actuator, you are getting 10 psi instead of 7 psi. This is a lot better than a boost controller as there is no chance of boost spikes, therefore safer for your turbo. You still need to ground that one wire to get rid of the two stage boost, and then bypass the solenoid. There is a tutorial somewhere here on SAU ;)
Link??
So with the actuator you don't need a boost controller??
Edited by Marco-R34GTT
https://www.sau.com.au/forums/topic/218768-r34-question/#findComment-3862622
Here you go Mark ;)
clicky
With the actuator you don't need a boost controller. This is how it works
First, ground the one wire mentioned in the tutorial. This will change it to constant high boost mode meaning istead of a two stage boost of 5 psi then 7 psi above 4500 rpm, you are running 7 psi all the time.
If you put the RB20 wastegate actuator in and bypass the solinoid, you now have 10 psi all the time. You have to bypass the solinoid cause it will limit you to 7 psi. The solinoid is what is used to create the two stage boost. Since you are not running a two stage boost anymore, you don't need it :P
Edited by NISZILA
https://www.sau.com.au/forums/topic/218768-r34-question/#findComment-3862674
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
