Well... if you want to get technical, it runs a two stage boost. First 5 psi and then up to 7psi at higher revs. You can earth the one wire and make it 7 psi all the time though. This is the same for the R33. R32's run 10 psi.
Just to clarify, I'm talking about GTT's, GTSt's here... not GTR's
https://www.sau.com.au/forums/topic/218768-r34-question/#findComment-3860135
Found it, R34 GTT Stock boost is 7psi, just under 0.5 bar.
R34 GTR is same as 32/33 GTR... which is what Topaz was referring to I believe.
Wow, I really thought the GTT's were 11psi like the 32GTR's. 7psi is shit! :P
Not sure what 33GTR's are stock, 34GTR's are 1bar stock.............................. I'm 95% sure
Edited by Topaz
https://www.sau.com.au/forums/topic/218768-r34-question/#findComment-3861541
That changes when you get the RB20 actuator yeah??
10 psi??? :P
You're doing that to your car aye??
https://www.sau.com.au/forums/topic/218768-r34-question/#findComment-3861829
i am running 0.85 bar(12 psi) daily.... izit bad then?? lol
12 psi will be fine, but you may want to check that its not leaning out at all. Upgrading your fuel pump is always a good idea when running more boost. Probably wouldn't go too much higher than that until you have some other bits and pieces to support it.
10 psi??? :)
Yep thats right :D Cause the R32's are 2 litres, they run 10 psi to make up for the smaller capacity. By changing to the RB20 wastegate actuator, you are getting 10 psi instead of 7 psi. This is a lot better than a boost controller as there is no chance of boost spikes, therefore safer for your turbo. You still need to ground that one wire to get rid of the two stage boost, and then bypass the solenoid. There is a tutorial somewhere here on SAU :)
https://www.sau.com.au/forums/topic/218768-r34-question/#findComment-3862342
Yep thats right :P Cause the R32's are 2 litres, they run 10 psi to make up for the smaller capacity. By changing to the RB20 wastegate actuator, you are getting 10 psi instead of 7 psi. This is a lot better than a boost controller as there is no chance of boost spikes, therefore safer for your turbo. You still need to ground that one wire to get rid of the two stage boost, and then bypass the solenoid. There is a tutorial somewhere here on SAU ;)
Link??
So with the actuator you don't need a boost controller??
Edited by Marco-R34GTT
https://www.sau.com.au/forums/topic/218768-r34-question/#findComment-3862622
Here you go Mark ;)
clicky
With the actuator you don't need a boost controller. This is how it works
First, ground the one wire mentioned in the tutorial. This will change it to constant high boost mode meaning istead of a two stage boost of 5 psi then 7 psi above 4500 rpm, you are running 7 psi all the time.
If you put the RB20 wastegate actuator in and bypass the solinoid, you now have 10 psi all the time. You have to bypass the solinoid cause it will limit you to 7 psi. The solinoid is what is used to create the two stage boost. Since you are not running a two stage boost anymore, you don't need it :P
Edited by NISZILA
https://www.sau.com.au/forums/topic/218768-r34-question/#findComment-3862674
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
