  • Replies 264
Nicholsons is always good... fairly cheap to and a good big carpark
http://www.nicholsons.net.au/
+1 for Nicholsons, they have a mean steak sandwich!!! Yummmmmmm
Keep on Topic, this is not a Whore Thread,
Bwhahahha
I would like to go, so I could bag out all the Uni students...... Looking at you Brady!
This isn't the boy scouts..
This is what we do...
okay so who wants to decide what...
less talking and let's actually make this less confusing...
and still, bnr#@... what's ya name dude i'll put you on the list and Coz are you going to come?
who else wants to come?
cheers,
Andrew :spank:
Seriously dude...
Best way to sort this out..
Make a poll, run it for a week/10 days... Then book to whichever has the highest number of votes..
That is my best suggestion... Some ppl are going to be pissed, but it is the most democratic option...
democratic eh... :P
where is this Nicholson's place?
a drive to Fremantle would be nice, i think with the plans we already had everyone was happy with that but i guess we can try to work something out...
had 14 people happy with Fremantle, if anyone has any objections just let us know and we'll hold a poll i guess, i have no problems and we have some time but yeah voice your opinions now eh...
i don't know how to create a poll either :spank:
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
