G'day everyone,
Just posting a "heads up" thread for people to get ready for our annual SAU NSW track day.
Its at Wakefield park raceway just outside Goulburn.
This will be classed as a "Driver training" day and all are welcome, and all types of cars a welcome, (cept for rotaries! :P j/k)
We are just finalising some details and the proper thread will be started asap.
So, saturday June 21st, gear up and lets go racing :D
Bring your friends as passengers are welcome on the day.
Stay tuned for more details, however please post in here if you are interested!
Cheers,
Chris
  • Replies 107
get the official lap timing up and running :)
if I was paying attention.. we wont be doing official timming because this is a driver training day and official timing means we cant have passengers.. which would mean we cant have the passengers in the car to give tips and stuff..
No official timing guys. Otherwise we cannot have passengers and training, but feel free to bring your own devices :)
(This is due to insurance)
mezmerized - Nice one mate!! Good to hear!
Hey guys,
Just a bit more info on what you'll need for the day
Race licence (CAMS or wakefield or AASA - can be had on the day)
*Helmet - ADR approved and no damage
*Long sleeve shirt and pants
Maybes, things to think about:
Good set of Tyres
Brake bled and pads and a service on all fluids and oils
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
