I read somewhere that a guy got his car to 185kw with a stock ecu.. possible? i want to get the most out of the stock ecu for the moment as i'm saving up to get a haltech ecu..
I have a stock ecu, 3inch dump, hi flo cat, 3 1/2 inch cat back, standard turbo, splitfire coils, pod filter, turbosmart bov and a turbosmart eboost2 (11psi) boostcontoller and i pulled 186kw@wheels.
but i am half way through heaps of other supporting mods - including gready plenum, Q45 90mm throttle, gready fuel rail, 650cc injectors, gready intercooler (spec R), and new microtech computer.
didnt get to do my first dyno at racepace :down: benno rang said its bad idea because turbo winding and really load but some ppl told me its because it used to be a track car and turbo could be boosted, it went up at 1 bar so it boosted to 13./14 psi i think, so not going to do my first till i have new turbo l :wub:
I wouldn't get coilpacks until you need them...spend the $4-500 on something else. I ran with standard coils and ~250rwkw for months without misfire, and only bought coilpacks because they came up at a great price brand new.
i agree i only have them because they were playing up and thought i'd spend the extra money to upgrade them, if i were you i would start with a pod filter, then exhaust and then same type of boost contoller. and see how that goes.
How did you get it to that? and who tuned your car?
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
