hey guys how are ya
i am changing my rego from vic to qld as i have moved up here.
been driving around with vic plates for 3 months so far.
i drive white r33 from brisbane area. ippy way
so just wondering wat the go is.
i changed to qld license today and they said that i have only 14 days to change to victorian license. is that true??
only 14 days. i thawt they gave u a couple of months.
and now more importantly i am just wondering wat the go is with changing over
it has a question about modifications, i have intercoler and boost comtroler and exhaust etc etc.
it says if answer yes u may need to get a modification plate or something???
and it says something about inspections and stuff??
back in the day it used to just be RWC and there ya go..
so any one got any idea?? do u jsut need a RWC or wat??
help would be appreciated. thanks
https://www.sau.com.au/forums/topic/219213-changing-to-qld-rego-from-victoria/
I had a look, by the sounds of it (question 16 on the form) that is only for major mods that do require a mod plate. So unless you have anything which actually does need a mod plate just put no. You shouldnt be able to get a RWC if you have un-modplated mods anyway.
Yes CTP IS compulsary, thats what th C stands for. you pay that at QLD transport.Its different tyep of insurance to third party fire and theft etc from just cars.
Edited by R334door
changing rego is easy
you have to get the right form, its the same form as registering a new car but seeing as the rego is already in your name there is no fee to change over other than the cost of buying number plates
you need a RWC and you need to take this with your form and your car to a QLD transport office
then they will inspect your car to check that the engin and VIN numbers match with your form and you're done. you obviously have to pay QLD rego but you will get a refund of your remaining VIC rego
CTP is a compulsory insurance that is normally included in the VIC rego already. in QLD they allocate you a CTP automatically but you can choose a different one if you like.
this is separate from insurance which you still need to change over to your new plates with your insurance company
best of luck!
Warren (ex-victorian)
Edited by WazR32GTSt
But you can't transfer rego interstate so there would still be the normal rego fee.
best of luck!
warren you make me laugh... quote yourself :D
and yes warren has confirmed it.. however there is an admin fee of $21.05 for new car rego.. i dont think they waive that fee even if it's your car (i mean dont forget this is the government here..
cliff.. i'm sure you meant in your question they giving you 14days to change to qld plates? (not vic license?).. just follow what warren has given you.. get a qld rwc (as rules on mods, etc are diff in all states) fill in the new car rego form (they dont recognise vic rego.. go down and register the car... while your there hand in your vic number plates.. they give you a receipt for the plates.. then you go on the vicroads website and get a form to mail (with receipt) and they will send you refund on your remaining rego..
Just Car insurance is easy jus update the address and plates.. but ctp is insurance on injuries to related parties.. diff from just car who insure the vehicles.. you get a choice of ctp insurance in qld.. (as the other guys stated)
i think it's roughly $340.00 for six months rego (including ctp)
done.. although that pretty much what warrren has summed up :(
Just reregistered my 34 recently.... all CTP is very very similar price in QLD within about $10 max from memory.... I'm with Allianz with mine ( I work for them, so I know wat I get for it... no discount still) 6 months is $333.00 total, $144.00 for ctp, rest was rego and fee and fee blah blah blah... 12 months was $634.95, $272.00 ctp rest is government pocket's stuff..
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
