Item:
HKS T04e 400hp
HKS external wastegate
HKS low mount cast manifold
3" intake pipe
Oil feed
Dump/front pipe
Screamer pipe
Unknown
Condition:
Perfect working order
Price:
$1,299 neg
PENDING PAYMENT
SOLD
To Fit: (What car)
RB20 & RB25
Melbourne - south eastern suburbs
Contact:
PM or call/SMS 0416 623 381 - No private numbers
Email/MSN [email protected]
Comments:
This thread is an expression of interest at this stage as this whole kit is currently running on my car and I will only remove once a sale is finalised
Alright down to business, complete bolt on kit for RB20/RB25 to make some decent street/track power
The kit comes with a HKS cast low mount manifold. This manifold is made of cast material same as the standard manifold, it also has an external gate port at the top. Sound better than the stainless manifolds in my opinion
Sits in the low mount position to retain a standard look and won't crack at any stage unlike stainless manifolds
You can also slap a big turbo on it and keep it low mount!!
The manifold is also wrapped in ACE heat wrap to help keep the heat in and get a nice quick spool
HKS external wastegate which is currently running a 0.7bar (10psi) spring, but I currently have it boosted up to 16 - 17psi on my RB20. It won't boost anymore as the spring is too weak so 17psi is about the most you will get with this spring in there
HKS T04e turbo which has tags to indicate it was rebuilt in Japan, when, I don't know but can confirm its in perfect working order with no abnormal or excessive shaft play at all
Comp cover is 0.5 and exhaust housing is .63, perfect for any RB20 or RB25 motor
I get full boost, 17psi by about 4,500 RPM on an internally standard RB20 motor, just the usual bolt on upgrades and it holds boost very strong all the way to 8,000 RPM
3" metal intake pipe to suit A31/R32/R33 - Has provision for blow off valve plumb back and rocker cover breather and also 1 vac line outlet. Also has silicon joiner for it to fit on the turbo
3" mild steel dump/front pipe that runs down to the cat converter, will also bolt straight onto any R32/R33 with no issues. It has a provision just before the end of the front pipe (where it meets the cat) to plumb back the external waste gate.
The external wastegate pipe is also mild steel and has a flex pipe thing built in for any movement, all fits nice and snug on any R32/R33
I can also have a atmo screamer pipe for the wastegate if you wish to block up the front pipe and run the ex gate atmo :P
Brand new PIRTEK braided oil feed line with all fittings. Will bolt straight up to any RB20/RB25 block and has all the brass fittings from the turbo to do so, line is quiet long so you could even run it on a high mount setup if you wanted too
Also have the metal oil return elbow that runs off the turbo
This is a complete kit, once again will bolt up to any RB20/RB25 motor and will drop straight into any R32/R33
I will throw in the bends off the turbo and also the joiners so you can retain all your standard cooler piping to the turbo as you would use with your standard turbo, I can say this setup looks very standard when done properly besides the external gate of course
Like I mentioned above, I will remove the kit once someone has secured the purchase and I am also willing to show the kit working on my car running 16 - 17 psi
Please don't waste my time, serious offers and interest only - Not separating at this stage either, just want a quick straight forward sale
Don't post comments in the thread if your not interested in purchasing, if you feel the need to comment please PM me
If I am missing any information let me know and I will post it up to the best of my knowledge
Few pictures below
:D
https://www.sau.com.au/forums/topic/219250-hks-turbo-kit-to-suit-rb20rb25/
Thanks mate
For those who are located interstate and have asked about shipping, I will have the kit freighted/couriered interstate at your expense
It wouldn't cost too much but just because its heavy and a few things are delicate I wouldn't trust Australia Post to ship it
Price is negotiable so PM me and we can work out a price including shipping :D
