  • Replies 167
the roads in rocky were shocking when the ripped the top few layers of road off to lay new stuff. Seems that the council has a constant plan to upgrade our roads. I have to admit I wa really shocked by the condition of the roads in brissy last week. I never remember them being that bad before.
  • 3 weeks later...
Uh oh, Col has spotted thread, closure immenent me thinks.
Mainly because chatting about local stuff outside the whoretown threads/wasteland is frowned upon.
I wonder how long the new widebay thread will last.......?
Hey ooki, have you heard of CQMSC (Central Queenslad Motor Sporting Club)
They run motorkhana's, 90% on dirt though, here in Rocky. They are CAMS affiliated so I'm going to one of thier monthly meetings this tuesday at diggers here in rocky, the general public are invited to attend, but have no voteing rights, which is understandable.
