iam after fmic for my r32 too i want the jast jap one but none in stock...and noone i no sells them dont no why but if anyone knows pm me thanks..i prob will just go with buying a greddy one off a shop on this forum..
so the fmic that cuts in the battery tray are legal if you dont have airbags.. 32 dont have airbags so its sweet? if so greedy fmic ftw
https://www.sau.com.au/forums/topic/219376-fmic-kit/page/2/#findComment-3872146
as before, i would not want to argue over it with the police. much rather get an fmic with inlet and outlet on the one side so i can retain the factory airbox etc. i'll wait till justjap get them back in stock. As for the core's importance ... agreed it does make a difference, but is it really "THAT" obvious for a daily driver that will not be going to the drags trying to reduce 0.01 seconds off his time?
i know this is debateable but still :)
https://www.sau.com.au/forums/topic/219376-fmic-kit/page/2/#findComment-3872399
i know this is debateable but still :blink:
+ 1 mate stick with the stealth kit. Iv made up my own kit that follows the same route as the cooling pro one, I painted it all in satin black and you can't even tell I have an intercooler.
My brother is getting his stealth kit for his stagea in the next few weeks.
https://www.sau.com.au/forums/topic/219376-fmic-kit/page/2/#findComment-3873455
