The garage cleanout continues!
HKS 2835R Internal wastegate
One used HKS turbo, includes actuator. Has T25 flange, bolts up to standard SR20 exhaust manifold - requires a spacer plate to suit an RB20/25. HKS rated at 420hp.
SOLD
Trust TD06-20G Turbo Kit RB20/25
Used, includes tuned length stainless exhaust manifold, Type R wastegate, Trust turbo, AFM to turbo pipe. Both the front housing and the front pipe have been polished.
$3500
HKS Hypermax R33 coilovers
Used, adjustable both on height and rebound. Pretty firm ride, great for circuit use.
$1800
Edit: D'oh, it's to suit an ECR33
Trust TD06-20G Turbo kit 13B
Used bolt on kit to suit 13B rotary, can be modified to suit RB20/25 just like Rob77's setup.
$2500
Trust stainless exhaust manifold + Type R wastegate - RB20/25
Used items, perfect condition
$2000
HKS EVC 4
Used item, works perfect (when set up!). Was installed in my car.
$500
Q45 90m AFM
Used item, perfect working order. Uncommon part, great for PowerFC users.
$350
Split dump-pipe
Stainless steel, to suit HKS 25-series turbos. Was fitted to my R33.
$300
Front mount intercooler
Small front mount intercooler, came out of an R32 but would suit most cars. Uses standard intercooler holes so no cutting. No pipes.
$500
Please email me at this address regarding these. Pictures will be uploaded at this webpage.
Guys, take my advice, grab the Q45 AFM while you can..350 sounds a good price, and also get a 90mm Apexi Filter..
I bought an adapter with my AFM before, but you can simply just joint the stock AFM wiring..There are three wires...PWR, signal and earth
Mark, yes it can.
Z32 is good for up to 300rwkw. Q45 is good for more than 300 rwkw.
I reckon you just need the Z32 dude, leave the Q45 for me OK ?? :P :P
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
