I usually use TOYO's but customers specified these.
Just want to find out others experiences, these things stick pretty well but on two of my high hp customer cars 270+rwkw we are experiencing tearing :spank: any one else finding the same?
https://www.sau.com.au/forums/topic/219401-bridgestone-adrenaline/
Interesting, never seen this on car tyres before. Big airplane tyres get it all the time, it's called chevron tearing or "chevroning". Sometimes the tears appear in little ^^^^ shapes other times they are just straight. I think from memory it's cause by the initial touchdown point before the antiskid has a chance to kick in. Unless the tyre starts loosing chunks of rubber or the tears are big you don't have to worry about it. With airplanes that it is :D
Would be interested to know what caused it on car tyres though, the only thing I can think of is the rubber is very soft and the car perhaps suffers from axle tramp...:w00t:
From the pictures that you have posted it doesnt look to me like "tearing", what it looks like is almost certainly a tread join separation.
With almost all UHP tyres the tread is joined on to the casing after the casing is put together, they're not one piece, when the tread is moulded on to the casing the manufacturer almost always deliberately overlaps the tread join to reduce the chance of seperation.
It looks like your tyres are "feathering" at the overlap point where the tread has been moulded.
This usually happens when the tyre has suffered from excess heat build up for an extended period (such as drift or track racing).
From my experience you should be able to wear the tyres down to the belts without the tread letting go (if they are built well) because where it is lifting is only the overlap point, the actual tread join would be further around the tyre underneath the top layer of tread.
If you are worried about it you should contact the manufacturer or wholesale distributor though.
I hope this helps :)
I hope this helps :P
im sure it is moulding issue causing the tearing / separation and have mentioned this to the dealer, unfortunatley they all (dealers) at this stage give blank looks.... tyre re-sellers not experts :rofl: i will send through some pics to B/S HO.
as both cars see ZERO drift or any real excessive abuse that other UHP tyres havent been able to handle.. Not real impressed with them so far.
I was planning on buying some 255 Adrenalin's soon, this aint good news :) Other then the tearing issue (which could be a bad batch or something i suppose), how are your customers and you finding the tyres? Good grip? Last a while? Any info would be great Trent, thanks.
Most tyre retailers wouldnt see this issue very often as it is not all that common in well made UHP tyres, of course Bridgestone are quite well known for their high quality standards. You are best off sending the photos in an e-mail to the importer / distributor who can then contact Bridgestone, they might be able to offer a manufacturers warranty ( I know we normally would ).
But as it is almost impossible to tell whether the tyres have been used in a motorsport application you may not get anything back.
Like I said, you will probably be able to run the tyres right down to the casing without them delaminating, as the actual tread join would still be intact, but the choice is yours. :P
hey your sig looks like our old skyline, is it from adelaide?
I bought it in Sydney from a private seller, I dont know if he was the first owner in Aus though...
It was stock standard when I got it except for the GTR bumper, grille and bonnet lip, cat back exhaust and Volk wheels.
OMG
I have that on one of my rear RE001s. I couldn't work out what it was! Looks exactly the same. 200rwkw S14 which sees a lot of mountain passes but I've never drifted on these RE001s. I'll try and get a picture of it tomorrow.
Anyone else? Should I take the tyre(s) back to Bridgestone and get them replaced? The one with the tear is basically new.
Edited by Equinox
OMG
Its not a tear... Refer previous posts.
If you are concerned about it, take it back to the shop where you bought it and show them... If they cant help, call the wholesale distributor directly and explain it.
You may be able to get a manufacturers warranty - No promises though, I dont know what Bridgestone's policies are.
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
