Ok time to ramp this up people. We need:
A) Excitement.
B) More entrants.
Can you all please tell all the people who you know like track or could be interested in it as we need more entrants to make this financially viable. If you are a keen and helpful club member put it in your signature and let's get this show on the road!!
I've told most of my friends... and their response has been generally soft saying they lack the monetary capacity :P
Won't stop me going, especially since I have paid lol
  • Replies 547
Posted Images
i've got another question, if i have my normal daily rims on the front, and stockies on the back, both with decent tread, is this an issue? all the rims and tyres are the same size, i just don't want to waste my daily tyres if i dont have to, but i will if i need to
You will probably go through front tyres too Zane so it might be worth changing the fronts too.
hhmmm i've thought this would happen, but my fronts aren't very good tyres so gives me an excuse to use them up n get better ones, man i go through some tyres :)
Quick question - Are there gonna be any "official" photo peoples there? Like Oz-event Photo or someone?
I'm official :)
We may have a few photographers there on the day. But nothing like HPI or anything.
Just seeing At some part of the day are we aloud to drift? sometimes they say yes but not sure with you guys. :(
No drifting allowed on the track at anytime especially down the straight. ( You will be pulled off if we see anything ) If we have enough time we may have a drift session or 2.
I'm official :(
Of course you are Corinne :-)
There are those guys called Oz-event photo who i might try and contact if that's cool with the club?
On other days they rock up in the morning, start snapping away, and by the end of the day have CD's ready to go of your car. They were around $30-$40 bucks, but you get nice hi-res shots
probably a 35-45 profile. on say a 235mm wide tyre.
the compound and wall stiffness of the side wall will make a greater difference than the profile though.
i.e. while a lower profile tyre has more inherent sidewall stiffness, a tyre of higher quality sidewall (in regards to stiffness design) with a larger profile will generally speaking, perform better.
I am! CAMS says I am! I even have a special book!
Anyways I doubt anyone would want to pay that much for their photos. (I'm sure I don't) I'm sure Xmetal or link can do a better deal then that. I would prefer to support their work.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
