I have had hours and hours of dyno tuning on a mircotech.
Cold start I had to sit on the starter for like 10seconds to get it started. (Haltech starts right away)
I would pull up at lights and the car would stall. (Haltech running idle has had zero problems.)
Haltech is so much better for GTR's (Due to 6 throttles).
All was turned by the same tuner.
https://www.sau.com.au/forums/topic/219592-microtech-lt8s/#findComment-3878435
Not true, it is common knowledge that single map sensors struggle with multi throttle arrangements, hence why PFC d'jetro uses 2 sensors, and autronic uses TPS/MAP combined.
^^^^ On the money!!!!!!^^^^^^^ >_<
https://www.sau.com.au/forums/topic/219592-microtech-lt8s/#findComment-3878452
  • 2 months later...
sorry to drag up an old thread, but dont all map based ecu's need throttle % input?
i had a ancient map based haltech e6a & that was .
im only asking cause im considering a s/hand microtech lt12s
Edited by norwest_rumbler
https://www.sau.com.au/forums/topic/219592-microtech-lt8s/#findComment-4072727
    • I'm with both M & D here. There's little harm, unless you're prone to getting annoyed by over-enthusiastic displays of wild optimism and/or stupidity**. And there is potential benefit from basking in the warm glow of schadenfreude, if you get something from that. **The bookface generation seem to think that if they can see something on the internet, then it must have been posted just before, because there is clearly absolutely no history when everything is served up on some sort of dash, fresh for your algorithm fed delectation.
    • It's sure fancy, you better go faster now (although I notice it is still bluetooth to the braking system for now, maybe plumb it in?) Will be interesting to see what you think of it and how much you use the adjustment
    • I've got to be honest, I don't see the harm in people asking on old posts.....I've got a lot of stuff lying around that I never update, and you never know who will remember they have something around
    • I was going to say the wife's lawnmower, but same concept
    • Well, yeah. But not with that nasty plastic cap. Well, actually it's a very nice plastic cap - given its job is only to keep the transport oil fill inside. But I wouldn't trust it to remain strong for years.
