haha ive got one lined up for $60 delivered from Ardie, just got to wait another day or two...
might have to take u up on that offer though with help putting it in haha
yeah ha ha no worries
they a piece of piss to do cauz 33 ones arent hydraulic they electronic so easssy assss :P
:):):bunny::bunny::bunny::bunny:
:bunny::bunny:
haha sounds like a plan haha, bring the Cans over to measure with? haha
something tells me you like rabbits haha
ha ha its a heaps cool pic
yeah bring sum piss over we can do it on a fri/sat night wit vaggy or sumfin ive been bored as f*k lately i need a engine or sumfin to work on lol...
anyone got a blown sr they want to sell?
Edited by Josh_r32
Just make sure you check your alignments when you are done as they can be thrown out. But yeah, they are a joke to fit compared to 32’s with their stupid hydraulics. Also, I suggest pulling the HICAS bulb in your cluster as it will stay on when you remove it
yeah we can only get it sooo good by eye, so best take it for wheel align after!!
yep that light gives u the shits hey lol
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
