Make:nissan
Model:R32 gtr
Milage:
Transmission:manual
Colour:silver
Complied?yes
RWC supplied?
Currently registered?yes setember 08
Price:10000
Contact:0412426573
Comments / Modifications:slling this GTR with a big end bearing gone....is not very noisy but there is definately a problem....shoud be able to fix for $1500 if you pull it out yourself and the crank is ok...guessing it would be as it's not very noisy.....
car has september rego cat back exhaust body is very straight ,currently has side skirts off to be repainted but they are all there....call for more details 0412426573
Images:
https://www.sau.com.au/forums/topic/219739-r32-gtr-update-with-pics-10000/
  • 3 weeks later...
I know the owner and seen this car as he offered it to me before he went overseas, this gtr is a pretty damn clean example, too cheap brad, you should fix it and sell it fixed mate, be worth heaps more
Yeah still for sale...it's a 1989 model...don't think the front bar is changed but it's missing the lower lip....
car will be for sale for one week longer then i will be pulling the motor out and and getting it repaired
if anyone wants to make some easy money and has time here is your chance...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
