hey guys
ok i was looking at upgrading my suspension to Tien Super Streets. They are going to go into a Skyline R32 gts-t.
the question i wanted to know is . are they cheap to buy them second hand for $700.00 and if they break rebuild them? or should i pay around 1600 and get them brand new?? also how much would it cost average price to rebuilt the tein's if they ever do break.
and another question would be what else brands can i find for the same price range?
I will be using them for rode and a bit of track work.
thanks
niran
https://www.sau.com.au/forums/topic/219815-tein-ss/
HSD Type R........$1450 new and they are the uprated ones over the Type S for i think $1200. Maybe get them cheaper else where. Ive had super streets on my car befor (both S13 silvias.) and i was not too happy with them, they did not go low at all and were kinda soft. My brother bought new ones and had the revalved and Fulcrum made custom springs so it could go lower, has plenty of travel and can sit the car on the floor if want to.
I currently have Tein HA's in my r32 and i am not happy with them either, they dont go lower enough, i am still above legal hieght and they are as low as they will go. I know HSDs go alot lower, and personally i belive they would be stronger than teins as they have a larger diameter rod too. Also instead of just spring seat adjustment they have shock hieght adjustment
https://www.sau.com.au/forums/topic/219815-tein-ss/#findComment-3876594
oh realy.. thanks for that aye. il look into that more. il try find some one who has a skyline in perth that has the SS and go in the car to see what it feels like. and then try the HSD's .. thanks for the help man
niran
https://www.sau.com.au/forums/topic/219815-tein-ss/#findComment-3876886
Highly recommend brand new as well. I have a set of SS in my 34GTT and they ride great. Before you bite the bullet and get some no brand cheapie, make sure you determine what the spring rates are first. Mine are 5k fronts and 4k rears which are just slightly above factory. Anything above these spring rates and you will find they ride harsher than normal. The SS is a perfect combo for street and track use.
https://www.sau.com.au/forums/topic/219815-tein-ss/#findComment-3876967
+1
got them in my 34 too. mine also has the electronic damping controller thing. goes from soft for road use to hard for the track at the push of a button :P i think the controller is like an extra $600 or something so i probably wouldnt have bought it, that setup was on the car when i got it.
https://www.sau.com.au/forums/topic/219815-tein-ss/#findComment-3880003
lol you u judge a coilover based on whether u can make the car touch the ground or not?
https://www.sau.com.au/forums/topic/219815-tein-ss/#findComment-3880689
Which means the entire weight of the car is being held on 4 skinny collars. And that's when the car is standing still. When it's moving, those 4 skinny alloy collars are expected to handle well over 6G (6 times the weight of the car) on many occasions just driving down a normal road. Not the collars themselves mind you, but the small number of threads inside the collars. Does that sound like a good idea in reliability and a lengthy life?
Cheers
Gary
https://www.sau.com.au/forums/topic/219815-tein-ss/#findComment-3881599
Cheers
Gary
Not doubting your knowledge or anything Gary, but I've seen quite a few 'upper market' coilovers that have adjustable height shocks too. I'll find some examples when i get home later.
Although I dont work in the suspension industry, I can't say I've seen/heard of any failing due to that design.
Have you come across any failing in your experience?
https://www.sau.com.au/forums/topic/219815-tein-ss/#findComment-3883683
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
