so stupid me decided to wash my engine bay today... went to malaga car wash, sprayed it with degreaser and then washed it off... when driving off the car felt different and would vibrate a bit so i stopped to make sure nothing was disconnected inthe engine bay. started driving again and i noticed it sounded like a wrx. so i drove home and it was vibrating all the way. when i took off it would shake, in 3rd going 40 i floored it and heard the turbo spinning but no boost coming on. drove really slow all teh way home nearly in tears :)
has it happened to anyone before and does anyone know what to do? is it the turbo??
i feel like crying right now >_<
https://www.sau.com.au/forums/topic/219932-cars-vibrating/
lol thats ok.
happened to me once before after getting my car detailed. i called the detailers to tell them, but they were in the pub and didnt care.
then i still didnt learn and the next time they sprayed my speakers with water...
I still use them though. Its convenient?
ps next time keep the water away from the engine cover at the top >_< (if you still have one)
https://www.sau.com.au/forums/topic/219932-cars-vibrating/#findComment-3878604
lmao, its funny how often this happens eh, im a detailer so i deal with it most days... generally its commodores or toyota's that do it... easy to sort out, or you could just keep driving and it will disappear...
Strange thing is, i have never detailed the engine of my car... lol :D
https://www.sau.com.au/forums/topic/219932-cars-vibrating/#findComment-3878830
LOL i understand you pain, hate it when something happens to your car when you have little knowledge so its good to see people here on sauwa help others out!!! Not like other clubs that simply put others down for *asking stupid questions* some people just judge too quickly!!!
https://www.sau.com.au/forums/topic/219932-cars-vibrating/#findComment-3878925
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
