1996 Nissan 180SX
White
Manual
105***kms
Blacktop SR20
Vertex Front & Rear Bars
Nismo side skirts
Trust Gearknob
Nismo Dash
Apexi AVCR
Front Mount + Piping
HKS SSQV
3" Turbo Back Exhuast
Custom intake pipe + Air Filter
Window Tints
Momo Steering Wheel
Pioneer MP3 Player + Sub and amp
Exedy Heavy Duty Clutch
Sunroof
Slotted Rotors front and back
Compressed Springs
Strut Brace
GTIR Turbo
Alarm and Immobiliser
Immac Interior
Body is Straight
There is Slight Damage on the rear bar
Small Dent on Driver Front Guard
Small Flake on Front Guard
DEC 2008 REGO
Always Used BP Ultimate or Mobil Feul
Serviced With Valvoline Oils Always
SXI180 Plates Included
Have lost interest, Also Lost License, And need a More economical car
$12500
Boost controller is now fixed, everything is immaculate now
The AME's are not included in the sale, as they are not my rims anymore
ALL GENUINE OFFERS CONSIDERED
Anymore Contact Mario on 0430 129 882
Thanks
Edited by Cro_boy_Mario
https://www.sau.com.au/forums/topic/220144-1996-nissan-180sx-white-manual-syd/
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
