hello all,
im considering importing a series 2 R33 but im not 100% sure on the process of importing to Adelaide and which importer to get to assist me, im looking for anyones advice on what i would have to do and perhaps some personal experiences with importing a similar car to Adelaide, once a a car is complied what sort of inspection do i have to go through at Regency etc.
the car im interested in: http://www.tradecarview.com/stock/detail.aspx?sid=1120904
any help would be greatly appreciated, thank you in advance.
Edited by AFTDRK
https://www.sau.com.au/forums/topic/220190-considering-importing/
Speak to Kristian - Iron Chef Imports
Site Here
I have just finished importing a Mitsubishi Legnum through him. Service was excellent, and its comforting to use someone local. He helped me out with a few problems along the way with regards to shipping and compliance, and made the whole process alot smoother than the bumpy ride it could have been.
For budget, DON'T stretch yourself, keep a few hundred $$ aside from what ANY importer quotes you as there is bound to be some unexpected cost, be it storage following shipping, parts need replacing on the car etc.
Also DONT import if you have a pregnant wife!! :D:):( I learnt this the hard way - pregnant women stress out too easy LOL
But basically, talk to Kristian, can't do better IMHO
:geek:
Krishy: Shipping depends on the size and weight of the vehicle. Shipping for the legnum was ~$2100 from Osaka Japan to Brisbane, then road transport to Adelaide. Import Duties & GST was $1,091 and I copped a 1 week storage fee at the docks of $478.50 because DOTARS were slow processing my Import Approval and it had to sit in storage waiting for Canberra to process it.... THUS why I said, keep $$ aside as you never know when something like the storage will happen.
Why would you import another 33 when there are a million of them here that people cant give away?
personal preference i guess, i havent found one i like here (maybe im not looking in the right places or im fussy :) ) and considering there are plenty of people who have succesfully imported a vehicle close to their preferences, then i thought heck, if its not too hard then i may consider it aswell.
Edited by AFTDRK
Hey that seems abit expensive Lee, was it put into a container by any chance?
Roll on/roll off is usually no more than $1200 unless there are other costs in your price for the dealer to bring it to the docks etc.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
