I bought my R34 N/A Sedan in January 08 from a private seller obviously looking to make a bit of money importing cars as it was only complied in December. I bought it with around 105,000kms and haven't had a major service done as yet, only a RACQ check to make sure everything was fine prior to purchasing.
Now the seller I bought the car from told me the timing belt had been changed. Also tells me that they change them at 75,000kms in Japan. Whether that's true or not I'm not sure, it's the only time I've heard such a thing.
Being better safe than sorry, my cars booked in for a service including the timing belt change.
I'm also looking at getting a custom 2.5" (or 2.25") catback exhaust and maybe a high flow cat fitted before hand. Ultimately I will be fitting extractors as well but this will be later down the track when budget permits.
With this in mind, would I be best to have aftermarket cam gears fitted whilst the mechanic will be changing the timing belt?
I've read somewhere (I think on these forums) that there's not much point in replacing the intake cam as you lose VCT. Can someone confirm this? The car is a daily driver so I'm more interested in a car that's going to have useable power than just outright power figures.
So I guess the big question now is:
Should I change the cam gear(s), if so is there a specific brand/model of cam gear I should be looking at? Are JJR cam gears anything to go by or is it much better to stick with the likes of HKS or Tomei?
Stick with the Nissan Genuine Timing Belt or go for a gates timing belt kit? The kit obviously comes with the seals etc… though I've read on the forums of some noise issues with the gates belts.
I would rather focus my money on simply doing the service and saving my money to put towards sway bars and exhaust upgrade, but if fitting an aftermarket timing belt and cam gear (s) is much more beneficial now cost-wise, I guess it's better to do it at the same time?
Looking forward to hearing your thoughts and advice.
Cheers
Nathan
Edited by N-DAWG
It is possible to change cam gears and keep NVCS.. Bear in mind you also need a cam gear that is compatable with you VVL engine.. Products.. i can't help you there..
In terms of belts.. Nissan vs. Gates.. Gates is a very well established brand.. and id simply say the cheaper of the two to save money.. Either of them is fine..
I haven't heard anything about having to change cam gears at 100,000km service.. I wouldnt bother for a performance reason yet.. gears are good after you sort out the basics..
is it possible to get aftgermarket cams that get rid of the vct ?
or should vct be kept? tbh i rekon it does nothing..
i looked at the dyno graph and it didn't look like much..
Edited by whyte
NVCS is actually quite noticeable... disable the solenoid and run the dyno again. overlap the sheets and voila!
unless you are going for some uber lumpy cams and massive head work i wouldn't throw it away.
That clears things up a lot for me, thanks guys!
Looks like I'll save my money / put it towards other parts, and leave the gears for now then. If I do end up doing cams it probably won't be for a couple of years. I was just thinking if it's worthwhile whilst they have the cams off to do seals.
So what are other people's thoughts on the Gates belt? The main reason I was looking at the Gate's belt as well is because they come in a kit with the seals etc.. required for a belt change.
I'm also looking at the Dayco timing belt kit as well from a pricing point: http://www.kudosmotorsports.com/catalog/pr.../products_id/50
How does the Dayco kit at $275 stack up against the Gate's timing belt kit for $349 ?
Edit: I'm also assuming that whilst the belt I'm looking at is listed for RB25DET Neo it is still suitable for a RB25DE?
Edited by N-DAWG
Tune it before BOTH runs, and you will see, it does bugger all. I know because I had it done on my car. If you just unplug it, the computer will still try to run the engine as though the VCT had hit its change over rpm.
Jack
http://www.skylinesaustralia.com/forums/Ma...=cams&st=20
thread that came up not long ago....i think sydneykid makes a recommendation for a set of poncams and few other bits and peices.
not sure...best bet would be to msg him...
i havnt heard of anyone selling any since ive been on the forums...
let me know if you get thru.
cheer.s
you may want to get your water pump replaced too whilst the belts are off
sounds like you dont know much of the cars background...
You're right there. I had the belt changed after all, got the gates belt (black) kit from Croydon. Turns out the belt had never been changed, so I have a lot more peace of mind now that it's been changed! I've been informed that the water pump is looking good for at least another 50,000kms worst case scenario, 80,000kms best case. So I'll wait till the it gets to that sort of mileage before I change the water pump, and besides, if it lasts the 80,000kms I can get another belt again at the same time.
cuppas is right, getting the water pump done now will save you in labour costs in the long run.
no point taking it all out again for something that could have been done initially.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
