I bought my R34 N/A Sedan in January 08 from a private seller obviously looking to make a bit of money importing cars as it was only complied in December. I bought it with around 105,000kms and haven't had a major service done as yet, only a RACQ check to make sure everything was fine prior to purchasing.
Now the seller I bought the car from told me the timing belt had been changed. Also tells me that they change them at 75,000kms in Japan. Whether that's true or not I'm not sure, it's the only time I've heard such a thing.
Being better safe than sorry, my cars booked in for a service including the timing belt change.
I'm also looking at getting a custom 2.5" (or 2.25") catback exhaust and maybe a high flow cat fitted before hand. Ultimately I will be fitting extractors as well but this will be later down the track when budget permits.
With this in mind, would I be best to have aftermarket cam gears fitted whilst the mechanic will be changing the timing belt?
I've read somewhere (I think on these forums) that there's not much point in replacing the intake cam as you lose VCT. Can someone confirm this? The car is a daily driver so I'm more interested in a car that's going to have useable power than just outright power figures.
So I guess the big question now is:
Should I change the cam gear(s), if so is there a specific brand/model of cam gear I should be looking at? Are JJR cam gears anything to go by or is it much better to stick with the likes of HKS or Tomei?
Stick with the Nissan Genuine Timing Belt or go for a gates timing belt kit? The kit obviously comes with the seals etc… though I've read on the forums of some noise issues with the gates belts.
I would rather focus my money on simply doing the service and saving my money to put towards sway bars and exhaust upgrade, but if fitting an aftermarket timing belt and cam gear (s) is much more beneficial now cost-wise, I guess it's better to do it at the same time?
Looking forward to hearing your thoughts and advice.
Cheers
Nathan
Edited by N-DAWG
It is possible to change cam gears and keep NVCS.. Bear in mind you also need a cam gear that is compatable with you VVL engine.. Products.. i can't help you there..
In terms of belts.. Nissan vs. Gates.. Gates is a very well established brand.. and id simply say the cheaper of the two to save money.. Either of them is fine..
I haven't heard anything about having to change cam gears at 100,000km service.. I wouldnt bother for a performance reason yet.. gears are good after you sort out the basics..
is it possible to get aftgermarket cams that get rid of the vct ?
or should vct be kept? tbh i rekon it does nothing..
i looked at the dyno graph and it didn't look like much..
Edited by whyte
NVCS is actually quite noticeable... disable the solenoid and run the dyno again. overlap the sheets and voila!
unless you are going for some uber lumpy cams and massive head work i wouldn't throw it away.
That clears things up a lot for me, thanks guys!
Looks like I'll save my money / put it towards other parts, and leave the gears for now then. If I do end up doing cams it probably won't be for a couple of years. I was just thinking if it's worthwhile whilst they have the cams off to do seals.
So what are other people's thoughts on the Gates belt? The main reason I was looking at the Gate's belt as well is because they come in a kit with the seals etc.. required for a belt change.
I'm also looking at the Dayco timing belt kit as well from a pricing point: http://www.kudosmotorsports.com/catalog/pr.../products_id/50
How does the Dayco kit at $275 stack up against the Gate's timing belt kit for $349 ?
Edit: I'm also assuming that whilst the belt I'm looking at is listed for RB25DET Neo it is still suitable for a RB25DE?
Edited by N-DAWG
Tune it before BOTH runs, and you will see, it does bugger all. I know because I had it done on my car. If you just unplug it, the computer will still try to run the engine as though the VCT had hit its change over rpm.
Jack
http://www.skylinesaustralia.com/forums/Ma...=cams&st=20
thread that came up not long ago....i think sydneykid makes a recommendation for a set of poncams and few other bits and peices.
not sure...best bet would be to msg him...
i havnt heard of anyone selling any since ive been on the forums...
let me know if you get thru.
cheer.s
you may want to get your water pump replaced too whilst the belts are off
sounds like you dont know much of the cars background...
You're right there. I had the belt changed after all, got the gates belt (black) kit from Croydon. Turns out the belt had never been changed, so I have a lot more peace of mind now that it's been changed! I've been informed that the water pump is looking good for at least another 50,000kms worst case scenario, 80,000kms best case. So I'll wait till the it gets to that sort of mileage before I change the water pump, and besides, if it lasts the 80,000kms I can get another belt again at the same time.
cuppas is right, getting the water pump done now will save you in labour costs in the long run.
no point taking it all out again for something that could have been done initially.
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
