obviously the turbo is the same as a garret then since MTQ use a T28 rebuild kit for them.
They are not the same...its has already been documented...first of all...its years older than the standard t28s we get on the sr20s...secondly...just because a t28 rebuild kit can be used does not mean its a t28...
as has been stated runnign more boost through the rb25 turbo is fine because its not working as hard on the rb20. the clutch is an exedy heavy duty.
also does anyone actually have facts or proof of 15psi beign a problem? the only proof i have so far is that my mates has been runnign 15psi all day everyday for the last 60,000km putting out 180kw at the rears with less mods. No noises coming from the turbo at all and it was checked for play a month or so ago when the engine bay was stripped and wire tucked.
on another note whats a good size/ brand of injectors?
It has been well documented too that 15psi on a rb25 turbo is a bad idea...even on a rb20...it will still be shortening the life of the turbo...if it runs 15psi but only reaches max boost during the occasional squirt then it might be ok...but hold it on full boost for a few laps on a track and see what happens...
the car wont be doing track work as yet i gotta get a new rear end strengthened and suspension fine tuned before i waste my time at a track this turbo will only be on till around december/january if all goes to plan with a aftermarket ecu.
who can recommend a good aftermarket exhaust manifold and is top or low mount a better option?
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
