  • Replies 40
Posted Images
Dont forget you run the risk of your paint cracking when they roll it. Thats why they'll never garantee it.
Try a different offset rims maybe?
ill take the risk, im quite happy with the rims, and cant really afford changing them over and bla bla bla
still no one has any good places in mind???
https://www.sau.com.au/forums/topic/220461-rolling-guards/#findComment-3890211
No need to get someone to roll your guards.
The tools you'll need are a heat gun, jack, a yellow pages book and a friend.
Heat up your guard where you want it to be 'rolled', jack car up, put yellow pages book in between guards and tyre, lower the car, start jumping on the car with your mate to 'pull' the guard out a little. Take book out and look at work. If you did it properly, it should no longer rub.
I'm not being a dickhead or anything about what I just posted. I've done it myself because the rubbing was so bad and the technique I used (and many other people) works.
Edit: Here's a picture of how mine went out. The tyre was originally sitting on the guard, or guard was originally sitting on the tyre. I used a pretty think book and this is how it turned out. The gap is too big now. :)
Edited by adam-__-
https://www.sau.com.au/forums/topic/220461-rolling-guards/#findComment-3890264
how thin [or thick(not sure of your typo)] was ur book exactly?? was it one of these little sh*tty yellow pages??
if i do consider doin this i dont wanna screw it up
https://www.sau.com.au/forums/topic/220461-rolling-guards/#findComment-3890478
$50 a corner....thats cheaper than I have been quoted elsewhere, and I have to travel miles to get there..what hours are you guys available?
how much do you charge to borrow it?
and after it screws my paint and body work, do I get the hook ups with a reputable pannel shop that does good work for cash? LOL
Edited by 33gtst
https://www.sau.com.au/forums/topic/220461-rolling-guards/#findComment-3890951
I first off used that sized book, but once I finished, it still rubbed so I tried it again with an extra book in between the gap, now it's too big... :P
Best thing to do would be to get a guard roller, but if you can't wait, the newspaper roll technique works and it doesn't crack your paint (it didn't on mine).
https://www.sau.com.au/forums/topic/220461-rolling-guards/#findComment-3890992
i rolled my gaurds with a steel pipe
put the pipe in between the tyre an gaurd, depending on how much u want it rolled depends on the angle you put the pipe on (slightly=more horizontal heavy=more vertical)
start from one side of the tyre an fit the pipe inbetween the gaurg an tyre, the get a mate to push ur car forward, which then the pipe will move along with the tyre which then you push down to get your gaurd the way u like it...
if your not keen, habib above me has a good price..
https://www.sau.com.au/forums/topic/220461-rolling-guards/#findComment-3891331
paint will only crack/peel if the guards arent heated properly...
best i got quoted was $80 for the rears
i'm just gonna heat em up and push em in with my hands
so where did u get this quote from?? sounds good
https://www.sau.com.au/forums/topic/220461-rolling-guards/#findComment-3891365
Yep, I did this with my rear guards. Just make sure you've got a solid pole. I crushed 2 poles out of 4 trying to roll/flare my rear guards.
https://www.sau.com.au/forums/topic/220461-rolling-guards/#findComment-3891367
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
    • Yuh, but that one is NLA. There might be an equivalent, but I haven't looked.
    • If you hadn't bought a stand alone one already, nismo make a bolt on adjustable FPR https://www.efisolutions.com.au/nismo-fuel-pressure-regulator-sr-rb-s13-180sx-r32
    • I know and understand they are principally the same. They both cause lock under decel, but the 1.5 nomenclature implies "half" or less locking force, or it allows for more slip or a speed differential between both wheels. Right now the driving manners with the 2 way is pretty rough on transient to full off throttle in the backroads. In other words letting off the throttle too rough is not forgiving, great for drifting, tougher for controlled grip driving.      Yeah, I have watched that video a couple times, I am more so just looking for the confirmation that both part numbers offer the same ramp architecture and are just different settings from the factory.     38420-RSS15-B5  38420-RSS20-B5
