do you just have the actuator or do you have the mounting bracket and the arm?
You said that you are going to use the standard arm but i don;t think that'll work because you need an arm with an internal thread and the factory actuator and arm are 1 piece.
Post up a pic' of the kit.
Here's my actuator setup, it a Garrett item but it's the same as the HKS ones;
Edited by D_stirls
Its a brand new actuator from nengun
holds the 1bar, being the "heavy duty" hks item
has the actuator top hat and rod, bag of nuts/washers and bottom screw rod for the actuator
plus the mounting bracket and braided rubber hose
the full kit as alan said.
yeah mate I had the $20 bleed valve on there but chucked it for a ebc pretty much when I did the safc install 2yrs ago.
its never held boost properly, last tune went from 14 down to 12's for 180ish kw,
with 1.0 bar + 1.2 bar dialed on the dual stage ebc Im confident now it will be good to go.
the exhaust is flowing well, got good intake and cooling, fueling is ok, got the adjusters to get the tune good, and (secrets out) Im doing a deal atm for a remapped chip + adapter.......
will get the adjusters safc/sitc/fpr/cam-gear all sorted once the ecu is done in around 2 months time, serviced, hope for 200kw+ for sure
im actually hoping for 220rwkw from the auto with the front driveshaft dropped at 17psi
but with the ecu remap, with ecu-chip adapter plate and data from japan, it wont be perfect out of the box, so still limited by the piggybacks.
but meh, not after top power, want perfect acceleration from the awd auto. traffic light GP's are all mine (yeerrrrrr~ lol !)
yeah maybe dean, we'll see what ryan wants to do, if he's up for the drive down south then its all good matey.
when ya getting the last of your pc parts old fella?
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
