Need 4 tyres with good treads in 205x55x16 (or is stock size x50?) for an R32 GTST to pass inspection. I already have rims with tyres but they are crap.
Can someone supply me with tyres or rims+tyres for loan or to buy for cheap? Would even consider trading my rims for yours + cash if thats easier.
Let me (Roland) know on <removed>, need them by wednesday next week, cheers guys ;)
Need to borrow Stock 33GTR wheels with good tyres, R34 GTT wheels will also do the job.
Needed for one day, just to pass ID inspect.
Muchly appreciate any help!
offering cash/booze for any assistance!
  • 3 weeks later...
i got a set of r34 wheels if you wana borrow em for a day mate, chuck us a pm if ya want em and we will sort something out
