Just do a slab of coke for everything :)
I'll get them out tomorrow. Might be able to drop them off after work tomorrow if u need.
sounds good , i get paid tomorrow :)
just gotta sort out hicas and then go through and hope for the best :):(:/ :/
Is there anyone that can help out with moving the track car around next week? ie: anyone with mates in the towing biz, or have access to a car trailer?
Adrian and I need to organise a tune at Turbo Tune at Edwardstown, and a wheel alignment at Port Adelaide, and obviously the car cannot be driven on the street. We aren't sure which days will we need transport yet, as we don't know when the car will be ready to roll out of BITSUS Customs, and how long it will be at the tuner's for.
any ideas/suggestions welcome.
cheers.
Nigel..
Need to borrow some working splitfires (or equivalent aftermarket coils) for a R34 RB25, i think my original ones are on the skids and want to make sure before i fork out $500 for a new set. Can hook you up with beer/cash for your time.
Thanks.
you can take mine off and see if you want
Thanks for the offer I borrowed one from the wreckers today and it was the problem so i bought it. Now I just need to get back on dyno to finish tuning it.
similar to above, looking for complete r33 gtr stock suspenson (struts n springs) to borrow just to pass ID inspection...
any help greatly appreciated!
im assuming youve got coilys in then? if you wanna come round and do all the work you can swap me for the time needed :)
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
