G'day,
We've got a used HKS SSQ BOV, once installed it won't open under load!
I tried using my finger, pushing it in from the front on the bov and it actually move backward (with a bit of pressure). Why wouldn't it open on my car? My engine is a 1.3lt turbo but that shouldn't matter shouldn't it? By the way i've hooked it up the CORRECT WAY.
Is HKS BOV spring tension inter-changeable? Is it ceased? If i spray some TLC in it would it work? Can i perform an operation on it by open it up?
https://www.sau.com.au/forums/topic/220778-hks-ssq-bov-ceased-or-not/
its probably just for show and not real :D
I was always under the impression HKS SSQV needs higher pressure than stock boost on skylines for it to open fully, otherwise could most of the time give flutter.
How much boost are you running?
Edited by R33Turbo
lol nice r33 turbo.
have u tried loosening the tension bolt on the back of the unit? 8-10psi and mine would work fine. i just installed it tho. didnt mess with the tention screw
Edited by r33cruiser
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
