R32 GTR Apexi pods and adapters in good condition, very clean. $160
R32 GTR stock headlights- $250 pair
R32 GTR front/rear calipers and rotors/lines. $300
R32 GTRstock front strut brace, in ok condition has marks on it (needs polish)- $80
R32 GTR stock rear bar (gunmetal grey, good condition_ - $100
R32 GTR stock rear wing (Gunmetal grey, has a few marks)- $100
R32 GTR stock fuel pump- $100
R32 GTR stock ECU- $100
R32 GTR stock 440cc injectors- $250.
R32 GTR stock 65mm AFM's $200 pair (near new, 6 months old)
All located in Melbourne, west suburbs.
Pick-up preferred, postage extra $
https://www.sau.com.au/forums/topic/220827-r32-gtr-parts-cheap/
Hey mate..
Ill take both R32 GTR front and rear strut braces..
can I see a pic?.. Are they the adjustable ones?
Willing to post to Syd?
Pm me
Edited by GTS4WD
My contact number is 0415-998-244 for anyone interested in the parts. First come first serve basis.
Also have a q45 afm with plug and a R32 GTR power FC and commander now for sale. Links below.
q45 afm
R32/r33 power FC
Tai
Please call Ed 0411392676 Re injectors
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
