  • Replies 92
Originally posted by hippy
i was being sarcastic ... but its like at least a week wait or something like that isn't it? maybe they treat girls better ..
I know u were being sarcastic!! I've always called them and they've told me to bring it down the next day. I doubt they treat girls better, I reckon they thought they could pull the wool over my eyes when I dealt with them.
Guest Miss_Nismo
Originally posted by EnricoPalazzo
MattR: Firstly this is not a RUMOUR as Martin told me himself. I was only replyin to Steves question. Thats my 2c
I think what matt is saying is that it is no-one elses business why martin left and you probably shouldn't make it public.
Sorry I asked the question, thought it was reasonable one, but I didnt want to start upsetting people:(
Appologies to all, just makes me start asking questions when someone moves on. I had my car tuned by martin, and I was quite happy with it.
But when it comes to tuning a car, usually the owner of the car gets to foot the bill if it all goes wrong, so I am very, very cautious.
Best to go with turbo tune if they offer a warranty:) I dont mind loosing a few kw as long as reliability is retained.
By the way, MattR, your car seems to be going alright, have you had any probs so far (with the tune) and who would you recommend?
There are a few guys around that would be perfectly OK and tune your car professionally. I think John at TT might be limited with the ECUs he deals with, i.e. Autronic only, might be wrong though.
I agree with Clint32 that you can't expect a tuner to give a garantee.
Jase, since yours is a 32, keeping the stock ECU and do a retune is an option, then your choice is limited re tuners, I think Martin @ Morpowa is the only guy in town that an do it...again correct me if I'm wrong there.
If you want to go aftermarket ECU, and therefore best for later engine upgrades, due to the 6 x throttle issue, MAP sensor ECUs have trouble with light load stuff, so keeping the MAFs is best, so Power FC or Motec is all that can be used with MAFs. Plenty of guys can tune with them, Martin (Morpowa), Shaun (RPM), Mildren, Tilbrooks (maybe not Motec), D1 Garage.
Ive tried to keep out of this one as long as possible, but will respond now.
1) Firstly, I dont have a lot of hair...so I dont have bad hair days. I am sure you may have taken that comment out of context
2) Mick Stanics high quality work speaks for itself. TRY09s was a good example of that. My differences with him are purely philosophical
3) Using Morpowas dyno facility has been fantastic. They are great guys, professional, and have leading edge equipment. Top marks.
4) Mark Tilbrook is a great bloke. We go back many years. Ive seen him perform absolute miracles. Top mechanic, and knows Skylines extremely well.
5) If anybody else here can 'real time' tune a standard Skyline management system for fuel/spark/boost cut/speed cut/rev cut, I would be interested to know
6) Tweaking a crank angle sensor, fuel pressure, and plug gap doesnt constitute tuning an engine
Just shortened it a bit to make my points clearer
The quote wasn't taken out of context, he didn't appear to happy with you back then.
It was when you had just left, so maybe the bad blood has now passed between you two?!?
Sh*t happens I guess. :D
:burnout:
Car is in with John at TT, found out about his warranties, basically if he can lock the ecu (eg motec, autronic) he will give a warranty, otherwise no.
Bit bizarre, I got quoted 'about $300' for the tune (by John), when I took the car in another guy said could be $500-$700 'cos power fcs can take sooo long to do?. I dont mind paying for a good tune, and I got told less than $300 by a couple of other places, but if it is that much, I dont think I will be back.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
