Purchased a 32 GTR afew weeks ago.
It is unregistered but has been complied.
6th cylinder has no compression
Here are my plans for the rebuild.
Looking at sending the engine over east to Lewis Engines.
Will cost $300 to freight it there and back
Basic rebuild will cost $5600 this consists of the following:
forged pistons and rings ARIAS
bore and hone
deck block
cracktest and grind crank
blueprint all clearances
ACL comp bearings
multi layer steel head gasket
reco head
gates race belt
waterpump
tensioners
Welch plugs
reco and modified oil pump
line hone main tunnels
resize rods
new bushes and arp rod bolts balanced
Was then thinking of paying an extra $350 for r33 jun collar
$699 for H Beam forged rods
Will then slap it back in running all stock gear.
After it is licensed i will then look for new turbo setup.
Is it worth keeping twins or going single?
Was thinking of finding some N1 turbos
What do you think of the setup?
Wanting to pull around 350rwkw maybe upto 400 late next year.
Will the bottom end listed be ok to handle that?
I know i shouldnt build an engine then stick stock turbos on there but i need to get it licenses asap.
Will keep stock boost untill i can replace the turbos/hi flow them.
Could even stick a single gt30/gt3540 on there.
Will be tuning stock ecu as i have her hardware and software to do it
https://www.sau.com.au/forums/topic/221613-my-new-gtr/
If you are looking for 350- 400 rwkw it is better to go something bigger than the N1s. If i'm not wrong, N1s probably give you 320 or 330 rwkw.
With your engine build, 400rwkw shouldn't be an issue.
Ever thought of getting an aftermarket ECU instead of re-map?
BTW, where's Lewis Engines?? :D
https://www.sau.com.au/forums/topic/221613-my-new-gtr/#findComment-3907498
http://www.lewisengines.com.au/
ATM im more worried about getting car licensed.
I would be happy with just over 300rwkw for quite awhile.
N1's seam to give good power they are bolt on and steel wheeled.
any power goals over 300rwkw will not be for awhile id rather a very streetable car than power monster.
I real time tuned on old 32 gts-t and found the stock ecu a joy to work with.
If GTRs in Japan can run megga power on stock ecu's i dont under stand why more people dont give it a go here.
https://www.sau.com.au/forums/topic/221613-my-new-gtr/#findComment-3907614
The build sounds awesome :D
I've heard only great things about the N1's, both street and drag/circuit.
They're almost as responsive as the stock ceramic GTR turbos but can make over 300awkw.
If i was you i'd seriously consider N1's (or a Garrett/HKS equivalent with similar A/R's).
The High-Octane R32 GTR, before it was totally rebuilt, ran N1's and pulled 400awkw from memory. Obviously that's a race engine with mega cams, but shows what the turbo's are capable of.
https://www.sau.com.au/forums/topic/221613-my-new-gtr/#findComment-3907680
Hey man
I had a similar engine rebuild, after this i purchased a set of R34 N1's and saw a very healthy 303awkw, with nearly stock everything apart from
full exhaust system and an apexi power fc. Couldnt say enough about the N1's, so responsive and street friendly. From what you're saying
they would sound just the thing. Good luck.
:P
https://www.sau.com.au/forums/topic/221613-my-new-gtr/#findComment-3907796
For 400rwkw I wouldn't want to be using a reconditioned stock oil pump. Go Jun, another $1000 (greenline.jp)
Also, what about Valve Guides? Head Studs? Sump Extension?
I personally wouldn't rebuild a 26 and retain the standard valve guides, seen and heard of too many guides dropping and taking a brand new motor with them.
Edited by Brockaz
https://www.sau.com.au/forums/topic/221613-my-new-gtr/#findComment-3909100
this round of mods is puerly to get car registered
things like oil pump and head work will be done in time.
will not be chasing any real power over stock until turbos get done even then it will only be very small increase.
400rwkw is a long term goal
https://www.sau.com.au/forums/topic/221613-my-new-gtr/#findComment-3909194
if you just wanna get the car running so you can get it on the road, probably your best bet would be to buy a motor from a wrecker. it would turn out way cheaper in the end. there would be no way you would catch me bolting on stock turbos to a fresh motor. you can get 300awkw+ out of stock motors easily. id say only build the motor if your chasing high power figures.
im not against rebuilds though. half way through my 2nd!.... :D
https://www.sau.com.au/forums/topic/221613-my-new-gtr/#findComment-3909329
i am chasing more than 300rwkw but not at first. no point buying second hand engine as i could put that money straight into the bottomend rebuild like i plan on doing
I will get stock turbos inspected before putting them back on if there not the best ill wont drive it untill i can get the n1's or somethig similar.
https://www.sau.com.au/forums/topic/221613-my-new-gtr/#findComment-3909378
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
