fmic is sold payment recived come guys make a offer on motor and box i want it gone.
Update on parts left
DBA 4000 seriers slotered rotors price drop $250 including pads 2000km old
Front and rear bars and one side skirt $300 ono for the lot or Pm for indervidals
cat and act back exhuast 3 inch jasma $300
front struts assmebley $130 for the pair
lower control arms $150 for the pair
stub axel assmebley make a offer
Motor complete and i mean absoulty complete with 78 000 km runs like a dream $1600
Gearbox in great nick no noises 78000km on it including a brand new exedy heavy duty clutct $1400
diff and cradle assmebley including cv sharfts $350 ono
Bonnet not a mark on it in white $200
Boot lid including wing $200 not a mark on it
Advan wheels still avaible price drop $800
and other little things from $10 pm for details
  • Replies 77
Hi mate i'm after the gearshift surround and knob..how much posted to Canberra 2905
sorry mate the gear boot is the only part in good condition if you want it make a offer
Hi mate,How much is your front and rear bars? Will it fit for a series 2 gtst??? Also price for the complete front mount and piping??? Thanks
Front bar needs refibreglassing and paint but rear bar is in pritty good nick you can have them for $250 and i am sorry front mount is sold
hey mate,
would you seperate the wing from the boot and post to Gold Coast? Also, aside from the surface rust, are the rotors in good nick?
Cheers
Edited by Musky
hey mate,
Cheers
Umm i'd prefer not to as it is a pain to package up but the rotors are in excellent condition there only 2000km old the surface rust basicly just wipes off
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
