AH, it's been pissing down here, so we've been seeing a heap of people in th If you're trainers in Syd are anything like ours here, you'll get your ass kicked if you just 'take your foot off the accelerator'. The point of defensive driving is to learn how avoid as much damage with as little effort as possible, in the case of a slide, continuing with it, but steering through it safely, to miss obstacles & get yourself straight again.
When I did race driving training courses they said the following: In a spin? both feet in. (that means, push down the clutch and the brake and wait till the world stops moving). if you loose control you've lost control: your best option at that point is to get the car stopped asap and that means no gas, just brake and wait. The car will also move in a predictable path that way, giving other cars (and people!) more opportunity to get out of its way.
  • Replies 45
Posted Images
Theres a difference between a slide (controllable sometimes) and spinning out. They aren't the same, you can recover a slide. shouldn't just put both feet in when your in a slide.
If your spinning out on the other hand I would probably put on the brakes etc.
Damn unlucky Anna, sorry to hear :) I must say however that I think the damage could have easily been worse so you should be happy that the car is still in good shape :) hope you get it back on the road soon.
This is the result of hitting a guard rail driving on a greasy road and accidently braking too hard from approx 60km/hr to miss a wallaby on Mc Carrs Creek(yes I know I should've hit it)
Strut brace is bent and the Chassis Rail so a writeoff unfortunately :D
Best of luck getting yours fixed and remember, it could of been worse!!
Steve.
Come on guys didn't wanna start an arguement here..
Damn unlucky Anna, sorry to hear :D I must say however that I think the damage could have easily been worse so you should be happy that the car is still in good shape :) hope you get it back on the road soon.
Strut brace is bent and the Chassis Rail so a writeoff unfortunately :)
Steve.
Hey Steve,
WOW! I hope everyone in the car was alright... I'm sorry to hear about your skyline.. believe me.. I know exactly how lucky I am.. did this happen just recently too.. you know I wouldn't mind if it was any other car but I love my skyline to bits.. second thought after 'are the kids alright' was "$20k, this car is worth $20k" (it's still being paid off).. I hope you find another car .. although it prolly won't be the same again.. may she rest in peace..
My baby is back on the rd.. I got her back yesterday and took her out on a leisurely cruise.. (with the encouragement of my partner) .. *sigh*.. it was heaven and I'm so fortunate it wasn't a 'write off'..
All sweet.. see you guys round :)
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
