Make: R32 GTR
Model: 1989
Milage: 61 XXX
Transmission: Manual
Colour: gray
Complied? YES
Currently registered? YES
Price: $28 000
Contact: PM
i no longer want to keep my GTR
i dont have enuff room for it and i dont have enuff time to enjoy it so im better of selling it
car is very well maintained ive spent alot of money on replacing parts which didnt need to be replaced just to keep it well maintained
Engine
HKS step1 camshafts 264/264
HKS adjustable camgears
HKS inlet manifold gasket
Gates timing belt
custom stainless heat treated billet CNC machined oil pump
R33 RB26 crank shaft
external oil return lines from cylinder head to sump
Garrett GT35R Ball Bearing turbo
TiAL 44mm external wastegate
screamer pipe
custom steampipe Manifold
custom dump pipe + front pipe
hi flow 3inch cat
X force cat back exhaust system
115mm intercooler
custom aluminum intercooler piping
custom intake pipe
custom air box
greddy blow of valve
custom catch can
aluminum radiator
Fuel System
SARD fuel reg
SARD 800cc injectors
Bosch 023 fuel pump
Management
Power FC D jetro
Power FC commander
Suspension and Brakes
cusco coil overs with swift springs
hicas lock bar
EndLess VN front pads
EndLess brake fluid
DriveTrain
HKS triple plate clutch
HKS fly wheel
Interior
Recaro SR3 Passenger & Driver side
Blitz ID3 boost controller
Gizzmo shift light
Defi-Style 3 Gauge Din Dash
Defi style boost gauge
Greddy remote control boost switch
Exterior
CR KAI 18 X 9.5 +12 BRONZE
Nismo side skirts and Nismo rear pods <----- not fitted yet
6000k HiD headlight kit
POWER: 316kw @ 16psi
Maintenance
2x cam seal
1x drive shaft seal
2x nissan cv boot kits
5.5L Penrite HPR40 40
1x endless VN front pads
0.5L endless brake fluid 50
1x reverse gear lock-out selector
2x earl's -6 adaptor
2x blanking cap
2x 16mm copper washer
2.5L mobil delvac synthetic diff oil
1x nissan water pump
1x nissan oil pump gasket
1x nissan front crank seal
2x earl's -12 weld-on fittings
1m earl's -12 braided line
2x nissan exhaust manifold gasket
Edited by STR8E180
https://www.sau.com.au/forums/topic/221973-1989-r32-gtr/
standard internals?
every thing listed is every thing done
standard piston's and rods if thats wat ur asking for
internal upgrades are basic the bottom has
billet cnc machined oil pump
brand new bottom end bearings
pretty much just freshened up the bottom end just for that extra piece of mind
the cylinder head has
hks step 1 cam shafts 264/264
hks adjustable cam gears
gates timing belt
all new geniune nissan oil seals
Edited by STR8E180
https://www.sau.com.au/forums/topic/221973-1989-r32-gtr/#findComment-3927722
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
