  • Replies 260
some useful information i received via email today
Just a couple of points I want everyone to be aware of this year relating to entries being submitted:
1. Photo's are required. Please send via email and include your details.
2. All entrants including clubs MUST have flooring to be eligible for judging.
3. All entrants must be registered and in the show by 10:00pm when lockdown will occur and disqualifications may apply after this time.
4. No private competitor regardless of being in Pro or Expert Class is allowed to actively promote a business by way of printed material, regardless of what sponsorship deals they have. In order to promote a business, either the competitor on behalf of the business or the business itself, will have to reach a trade agreement with Auto Salon.
Just quietly Craig, it doesnt just double, it goes to about $250 ish per person instead of $80. That info is from the Autosalon application form
$250 :D f**k! For $80, I might be keen to enter the Stagea ... but not $250. What are the other 'hidden' extras?
So those with (for example) a BoostWorx sticker on the back window are not allowed? Thats a bit harsh.
sulking id say.
he said '' you can find someone else for A.S, cos im out'' during that whole ''ban'' thingy
so i did. and guess what, IT LOOKS 10 X BETTER!
Figures :)
Edited by RubyRS4
Figures :D
it says printed material. so you could have said stickers on your car, but no business flyers
Edited by Matty 31
im sure they would be more understanding with ''tuned by'' stickers. well i hope so any way!
ruby, would be good to have the stag in there!
the only hidden costs will be flooring etc when devided by 7 of us = f**k all.
if it was specifically for flyers then it should have said that, however it is saying printed material, which can mean stickers, business cards, flyers, banners etc.
as it does not specify exactly what printed material is then we can only assume it includes any sort of printed material as mentioned above.
Hmm, reckon I could have the $80 before the 25th deadline.
Biggest problem is I got a trip interstate coming up and I'm swapping my Days kit for a Dolphin kit. If it doesn't fit just right (FMIC and all) and doesn't get colour matched quickly, the Stagea won't be presentable for the show.
Take me in as a very serious "maybe". So where do I get the application form from? I'm sure its been said, but I'm feeling lazy tonight. :P
DUE TO LACK OF COMMITTMENT, INTEREST AND PEOPLE PULLING OUT,
THIS YEARS SAU DISPLAY AT AUTOSALON
HAS BEEN CANCELLED.
IT HAS BEEN LEFT TO LATE
WITH THE AMOUNT OF WORK THAT STILL HAS TO BE DONE
TO MAKE A DECENT DISPLAY.
THIS WAS A COMBINED DECISION BY THE ORGANISERS.
SORRY TO ALL THAT WHERE LOOKING FORWORD TO IT.
THANKS.
CRAIG, GUY AND FLICK.
craig i know my car aint too hot but if u need ppl to do the display ill be more than happy to put my car in! im sure scott will too! and even adam!
we need to have the sau display!!
ill have my gtr bar on and painted! but my overall paint isnt the best!
scott and adams cars r in great nic so im mor ethan happy to go in to have the display!!
its not just the cars dropping out though...we still need flooring, lighting etc.
i have never done anything like this before, so im not sure how to organise anything
and flick has been really busy herself..
its pretty dissappointing i know.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
